Question about Onkyo TX-SR605 Receiver
My receiver powers on fine but no signal output what so ever in all inputs (HDMI, Component, RCA, S-Video). I have done factory reset as well. Still of no help. I tried to connect another surge protector to the one this receiver was connected. New surge protector I tried to connect was defective and caused some sparks. Since then I am having this issue. Not sure what part may have failed. Any help or suggestions is very much appreciated
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Posted on Feb 06, 2008
  • 290 Answers
SOURCE: HDMI only for video and sound through regular audio input
DVI does NOT support sound unlike HDMI. Hopefully your PC has a Co-axial S/PDIF digital output. If not you might want to spend the $50 and buy a nice one from Creative. Modern motherboards are even coming with HDMI built-in but that's NOT your situation. I use a 15" DVI to HDMI cable but you are probably using an adapter and the a regular HDMI cable. Get co-axial digital audio cable of the right length and connect it to the co-axial inputs (they're in the upper corner). Use the remote's set-up button and select the "Digital Input" option. This is very powerful. You can assign any of the Optical or Co-axial inputs to any associated device.
I have my PC as Video 3 with sound coming in via HDMI which I assign under the "HDMI Video" menu and sound under the "Digital Input" as "Coax1". I use "Coax2" for the DVD player that lacks an optical output. If you use regular analog you are screwed as you found out. I usually use the headphone jack and an extension cable with the Computer and watch on it's monitor.
All HDTV sets are **** compared to a decent computer monitor. The deliver MUCH clearer video and much higher resolutions that shitty the 1080 HDTV maxes out at. ATSC is **** compared to a PC. Grated, cable is junk compared to ATSC at 1080i but that's another story. Yet, comparing ATSC to a computer is like comparing NTSC or digital cables' crappy 480i with ATSC at 1080i. It that much greater. At least 720p is wide screened unlike 480i garbage that's most of Comcast's "HD" digital junk.
Posted on Mar 01, 2009
SOURCE: Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Posted on Oct 20, 2009
Testimonial: "Found this answer hidden in the Owners manual."
  • 8546 Answers
SOURCE: I have an Onkyo TX-SR605 AV receiver that just
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Posted on Nov 28, 2009
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Component input no HDMI output
The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
Apr 15, 2010 | Marantz SR5001
What is the correct wiring connection using hdmi and optical cables from a lcd tv to yamaha yht292
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Sep 19, 2009 | Yamaha YHT-390 Theater System
RCA HD52LP: Composite video inputs don't work
RCA Authorized service tech looked at it. He determined that the DM Module need to be replaced. The part alone costs $550 + labor. Since the HDMI and component video inputs seem to work, he suggested buying a VCR DVD combo with HDMI output which would be far less than repairing the tv itself. I'n researching the possibility of purchasing the part myself.
Jun 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
No audio or video with HDMI connedction
May 05, 2008 | Onkyo TX-SR605 Receiver
No video output using either HDMI or component video
Make sure that these inputs are enabled. I'd have to confirm within the manual, but I believe that these have the HDMI section disabled by default.
Mar 21, 2008 | Sony STR-DG510 Receiver
Onkyo TX-SR605 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
