Question about Plumbing
My kitchen sink single-handle faucet with pull-out spout works fine on spray but on regular the water just dribbles out.
  • 25 Answers
I'm not sure what model you have, but it sounds like the aerator is clogged. It's the round piece with the screen on it. Probably has some debris in it. The spray probably comes out around the main aerator and that's why the spray is fine. If you can post a picture, it would greatly help. You can usually unscrew the screen and clean it. If you pull out the handle and face it toward you, it will loosen by rotating it counter clock wise. Hope this helps.
Posted on Aug 29, 2013
3 Suggested Answers
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
  • 365 Answers
SOURCE: hot water flow is fine to the bath but to the
Check the end of the tap where the water comes out, if there is a fine filter on there it may be blocked, unscrew the end where the filter is and clean, if clean you have a restriction in the pipes
Posted on Feb 09, 2011
Faucet leaking at tee where hot and cold connect to spout
The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
source Best Kitchen Faucets
Feb 03, 2012 | Kohler Fort© Widespread Lavatory Faucet...
I replaced the cartridges in my moen kitchen 2 handle faucet.I used danco 6s-1h/c. the hot side works correctly. the cold side just dribbles out. no idea how to solve this one.
by dribble out I guess you mean that the water is not flowing out the way you want?
first thing I would do is remove the coldside cartridge and test the water flow to that point. If the water is free flowing ( yes its a bit messy) use a second person one to open the valve ubder the sink the other to cup over the top of the open side of the faucet.
if that has good flow then while the cold is still openhold you hand over the spout and turn on the out water to us that to back blow the tube that goes to the spout.
Hope this works out for you best of luck
Tom
Sep 12, 2011 | Moen Banbury Collection 2 handle Kitchen...
No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
Water is dripping out the back of the the Danza 61/9 kitchen faucet
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Feb 05, 2011 | Danze D403412 Melrose Single Handle...
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Mar 19, 2010 | Kohler Fairfax Single Control Lavatory...
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
35 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
