Question about Gbc Heatseal H320 Laminator, 12.5" Wide, 5 mil Maximum Document Thickness, Black
Heatseal h320 laminator doesn't pull the laminator sheet completely through the machine
3 Suggested Answers
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
Can you delaminate a glossy movie poster?
Norine, if indeed 10% did laminate, In all probability it will wreck the poster try to remove it. I am not sure if it will work, could you run the poster through the laminating machine a second time.
May 06, 2016 | Gbc HeatSeal Ultima 65 Roll Laminator
My laminator suddenly stopped working when it was plugged in. what do I do?
Check the circuit breaker on the bottom left corner of the machine. It is under the machine. You may need assistance lifting the laminator a few inches to get your fingers under it. Push on it and listen or feel for it to click. If it continues to open after you plug it in then you may have a problem with the machine electronics. I also have had weak circuit breakers that needed to be replaced.
Dec 09, 2015 | Gbc Heatseal H320 Laminator, 12.5" Wide, 5...
Where is the fuse?
The Circuit breaker is located on the underside of the machine near where the electrical cord goes into the laminator. West Laminating Svcs 405-324-6092
Aug 12, 2015 | Gbc HeatSeal Ultima 65 Laminating System
How do I remove adhesive from rollers?
I have had this issue before when the laminating sheets were put in incorrectly (open side inserted as opposed to closed side inserted). Unfortunately, the manufacturer said that the machine is not repairable, and I had to replace it.
Oct 16, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Film is wrapping around bottom roller instead of going out. how do I get it unwrapped?
Get a scotch brite general purpose pad, be sure to let machine cool down before you start to cleaned roller. And you can thread your laminate film.
Sep 03, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Gbc Heatseal H320 Laminator, 12.5" Wide, 5 mil Maximum Document Thickness, Black Logo
32 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
