Question about LG GC-051SS Compact Refrigerator
I have a 1.7 mini fridge that stopped working . the only thing that works is the LED?
How to fix it?
Contact Sharp, there are no aftermarket parts for that unit yet.
Oct 10, 2016 | Sharp Refrigerators
LED Light issue on a Sharp French door fridge SJFB624V
We encourage you to contact Customer Care either via email at ccare@sharp.net.au, or by phone on 1300 135 022
Oct 05, 2016 | Sharp Refrigerators
LG Refrigerator model LFC20740ST Freezer is fine, but Refrigerator is not cold.
Try adjusting the thermostat knob up a bit, it should be near the leds, maybe under a cover. Seveen years is not very old but where your health might be at risk from bacteria maybe you might be justified in looking at a new machine. I refuse to call in repair people any more, once something breaks it seems to become a habit, if electrical items cna be said to have habits.
Maybe a new thermostat /seitch might cure the problem
Jun 18, 2015 | LG Refrigerators
LED Mini-light string stopped working
these lights have what is called a driver it should be either a 12 or a 24 volt DC output this driver can usually be replaced never worked with this specific light though installed the freezer led case lighting at all smiths stores
Feb 09, 2013 | Home
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
Danby mini fridge model dcr054w has stopped working the thing in the back is extremly hot and the fridge no longer gets cold, i turn the knob and i hear a click but the fridge doesnt actually turn on. the...
This is a problem with the 'Motor Run Capacitor'
What you suggest is exactly what happens when this part fails.
Unplug - and look carefully around the connections to the compressor - there should be a cylinder with 2 connections on it. Read what value it says (like 250V 50pf) - and order a replacement from a parts store.
Fit it any way round - it doesnt matter.
plug back in and should work 100%
Cost about - $5
Dec 27, 2010 | Microwave Ovens
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Hello, my daewoo fridge freezer has stopped working. The light comes on & it sounds normal, any suggestions?
SOMETHINGS LIKE THAT YOU CAN UNPLUG FOR A WHILE THEN PLUG BACK IN AND THEY WILL MAGICALLY WORK AGAIN, I GOT A NON WORKING MINI FRIDGE FROM CRAIGSLIST AND THE GUY SAID IT DIDN'T GET COLD, SO I ASKED HIM SOME QUESTIONS ABOUT IT AND HE ANSWERED THEN AND I ENDED UP TAKING THE FREE MINI FRIDGE HOME , ALL I DID TO MAKE IT WORK AS UNPLUGGED IT FROM THE WALL AND CHECKED ALL THE CONECTORS ON THE BACK NEAR THE COMPRESSOR, I DID THAT THEN PLUGED THEM BACK IN AND I HEARD THE COMPRESSOR START TO KICK ON AND WAS LIKE YES AND NO I HAVE A GREAT LIL MINI FRIDGE TO KEEP SODA FRESH AND CHILLED , SOMETIMES I GET A POP TO EXPLODE IN THE FRIDGE BECAUSE IT IS SO COLD INSIDE
Jun 25, 2009 | Freezers
Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Jun 06, 2009 | Haier HRT02WNC Compact Refrigerator
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
LG GC-051SS Compact Refrigerator Logo
24 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
