Question about Aquatic AV AQ-RF-3 Remote Control
I need to sync my new Aquatic AV Remote (AQ-RF-34) but cannot find any instructions.
    Top Expert:
  • Aquatic AV Master
  • 12,223 Answers
Download from www.retrevo.com or www.manualslib.com
God bless you
Posted on Aug 01, 2013
Fireplace remote control no longer works correctly
To re-sync your Honeywell 8220 transmitter to the valve: Turn the Local/Remote switch on your valve to Local. Then switch it back to Remote. Within 10 seconds of switching it to Remote, you need to press the Flame button on your transmitter. This will re-sync your transmitter to the receiver in the valve. Replacement transmitters and valves are no longer available for this system, they were discontinued by Honeywell and they are completely out of stock. Monessen Hearth Systems (now owns Majestic, Vermont, etc) has a retrofit kit with a new valve, pilot assy, and remote for these old RF units. (expensive, but cheaper than a new fireplace). FYI, aftermarket remotes are NOT compatible with this Honeywell system.
Nov 24, 2012 | Televison & Video
How to connect xbox to jvc av-28gt1sjf
I assume that since you do not have remote you cannot choose another AV channel on your TV. If so you can use the RF input using a RF converter to AUDIO /VIDEO or if not the sky input must be shared through a VCR/DVD or multimedia/DTS amplifier
Nov 30, 2011 | JVC AV-28GT1B 28" TV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
Model no. dtq2605fc how do we hook up a dvd player to this?
There are several ways to hook up a DVD player to a TV.
The simplest method, which works with any TV, is to use the DVD player's RF (radio frequency) output on channel 3 or 4, connect the output cable to the TV's antenna jack, and put the TV on the appropriate channel. There are two problems with this method, though. First, I'm not aware of any new players that have RF output these days. The manufacturers don't include it, figuring you'll be using the direct audio and video outputs. So if you're trying to connect a new player, you likely don't have this option. Second, if the player does have RF out, it's usually not stereo sound and the picture quality can suffer.
If the set has AV input jacks available, you would use those and select the AV input from the remote control or front panel. There are some possible problems with this method too. The biggest one is that if you've lost or thrown away the original remote, you might not be able to select the AV input. (Don't laugh, many people don't realize they should keep the original remote even if they never use it.) And on TV sets with only mono sound, you need a Y-adapter cable to combine the right and left audio outputs into one channel, so you lose any stereo effects.
The last way is for TVs without an AV input and DVD players without RF output. You use an RF converter (also called an RF modulator), which takes the audio and video signals from the player and makes a channel 3 or 4 signal you can tune in as I described earlier. RF converters are available at Radio Shack stores, most TV retailers and from many sources online. They're easy to connect, but you'll need an AC outlet nearby since they need power.
One of these methods will work for you, and you'll be watching DVDs soon. Thanks for using Fixya!
Apr 05, 2011 | Daewoo DTQ-13V1FC TV
Remote control not recognizing codes
Codes for many of our TVs can be found at InsigniaProducts.com. For the Blu-ray player, we recommend using your universal remote's scan or learning feature.
Apr 28, 2010 | Hughes HRMC9 Remote Control
Aquatic Airjet studio 34 seeping water from sides
issue with the Mfg process. needs to be exchanges with the factory. it cannot be fixed and expected to be ok for the life of your home.
Nov 14, 2009 | Whirlpool Aquatic Hotsoak 60x32 White...
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
Aquatic AV AQ-RF-3 Remote Control Logo
315 people viewed this question
Top Aquatic AV Televison & Video Experts
Are you an Aquatic AV Televison and Video Expert? Answer questions, earn points and help others
