Question about Gigabyte GA-G41M-Combo Motherboard
Hard disk gb maximum
I wanna buy 4 TB HDD for my PC but will my G41m-combo motherboard can take the load of 4 TB HDD pls reply urgently
  • Dreamornaut
    Dreamornaut Nov 07, 2013
    To clarify, you would not be able to use a 4TB HDD if you are using a 32 bit OS. So make sure you are using something like 64 bit Windows 7 or so on. Otherwise you should be fine,
  • Gigabyte Master
  • 3,606 Answers
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3505#dl
The mainboard does not have a limit for the harddrive size.
But the windows system sometimes have a limit especially windows xp.
A new sata driver or a bios upgrade is sometimes needed when you add a big harddrive.
Note: take care not to flash the bios with a wrong one if needed.
And also the new drive must be formatted ( in NTFS format ) before you can use it.
If you still run windows xp, try to make more partitions, so windows can see the new drives.
Other system like windows 7, does not have this limit.
Good luck
Posted on Aug 01, 2013
4 Suggested Answers
  • 298 Answers
SOURCE: my motherboard cant detect hard disk ,disk driver
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Posted on Dec 17, 2010
issken
  • 1472 Answers
SOURCE: I am having problems with
marathawarri
From what you have describe is that Windows is having some issues. Since you upgraded to a new motherboard I would like to know if you reinstalled your Windows for your new motherboard. This is something you need to do when you change out your motherboard. Yes alot of time Windows will still boot but to sync it up properly with the new motherboard you need to reinstall Windows.
Let me know if you have already done this and how long ago this was done so we can look at other possible problems.
Issken
http://www.fixya.com/users/issken
Posted on Feb 24, 2011
bronk50
  • 27725 Answers
SOURCE: how to update bios on mobo g41m-combo
Upgrading your BIOS
Now lets go through the various procedures needed to update your motherboards BIOS.
First you need to find out if there is a BIOS update available for your motherboard model, and if there is, whether you need it. Before we go searching for that information, you will need to locate your motherboard model number/name.
This can be done by looking at the documentation that came with your system, or even just by opening up the case and looking for the name silk screened onto the motherboard.
If you have a system that was built by a major manufacturer, such as Dell or IBM, look on the manufacturers website under your systems name or number to find updates.
If your computer was assembled by a smaller manufacturer, look for the motherboard manual to identify it. If this fails, use a program like Sisoft's Sandra to identify your motherboard model and manufacturer.
To determine your motherboard make and model through Sandra first down load and install the program. Start up Sandra and double click mainboard information.
This should give you both the manufacturers name, and the model number of your motherboard. Note down that information.
Once you have your motherboard manufacturer name and model, its time to find your motherboard's model, current BIOS revision and look up what newer BIOS revisions are available.
There are two ways to do this, the first through the manufacturers automatic BIOS update software, and the second by searching through the manufacturers website support section.
hope this helps
Posted on Aug 11, 2012
Onboard sound
1.check the speakers.
2.check the cabels to the speakers.
3.I/O-shields lightgreen contact is audio out-put
4.go to services and RESTART windows AUDIO.
Nov 05, 2013 | Gigabyte GA-G41M-Combo Motherboard
Hard disk tb maximum
Normally you wouldn't have problem with 2TB. The problem is beyond that.
Jul 31, 2013 | Gigabyte GA-G41M-Combo Motherboard
AcerAspire M1641 total capacity of all HDDs limited by MCP73VE mb
It is up to 1TB per drive. RAM is totally different and has nothing to do with HDD capacity.
Jul 23, 2010 | Acer Aspire M1641-U1521A PC Desktop
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
What is the maximum size of HDD supported on a mother board say MSI board say - K8MM-V (MS-7142) ? How do we detrmine this value ?
Dear sir,
i dont think there is any maximum size of HDD supported by any motherboard.....
But now a days 320 GB is the maximum size of HDD attached with any pc....
do reply
Abhinav
Jan 23, 2009 | MSI K8MM-V Motherboard
What is maximum memory size and speed for a P4M800PRO-M v2 motherboard
Hi!the maximum of memory capacity that support is up to 2G DDR Socket and this motherboard that support LGA775 Intel Core 2Duo Processor.by:danz
Nov 21, 2008 | EliteGroup Computers & Internet
Gigabyte GA-G41M-Combo Motherboard Logo
74 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
