Question about Gigabyte GA-G41M-Combo Motherboard
Hard disk tb maximum
I wanna buy 2-4 TB HDD for my PC but is my motherboard capable of taking the load of 4tb hdd internal pls reply need urgent answer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
Normally you wouldn't have problem with 2TB. The problem is beyond that.
Posted on Mar 29, 2014
3 Suggested Answers
willem52
  • 359 Answers
SOURCE: sir,i have install 3 sata
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Posted on Sep 25, 2011
damnor01
  • 1179 Answers
SOURCE: Gigabyte GA-8I915ME-G Motherboard + 1 TB WD HDD
Insert the SATA and Power connector, enter the BIOS and ensure that SATA 2.0 controller is enabled.
Now boot into Windows and click control panel.
Double click Administrative tools and double click Computer Management.
Left on screen: Select Disk Management under the heading, storage.
Here is where the hard drive should be detected. If not present click action, followed by refresh.
Now select your new drive and format it using NTFS.
Take care!
damnor01
Posted on Jun 07, 2012
DRIVER FOR ST31500541AS
when you buy a USB HDD the HDD comes preloaded with the drivers it needs to work, if it doesn't load them, then it is most likely that the caddy has failed. open it up and attach the HDD to the inside of your PC
Jan 13, 2014 | Seagate ST31500541AS 1.5 TB USB Hard Drive
Hard disk gb maximum
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3505#dl
The mainboard does not have a limit for the harddrive size.
But the windows system sometimes have a limit especially windows xp.
A new sata driver or a bios upgrade is sometimes needed when you add a big harddrive.
Note: take care not to flash the bios with a wrong one if needed.
And also the new drive must be formatted ( in NTFS format ) before you can use it.
If you still run windows xp, try to make more partitions, so windows can see the new drives.
Other system like windows 7, does not have this limit.
Good luck
Jul 31, 2013 | Gigabyte GA-G41M-Combo Motherboard
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
Take care!
damnor01
Jun 07, 2012 | Gigabyte GA-8I915ME-G Motherboard
My desktop model is Compaq SR5213 with 250G harddisk. Recently, I would add a new internal hard disk (3.5", 1 TB), is it possible? As I don't want to buy a external hard disk. thanks
You can add 1 TB hard as additional to 250 GB Hard disk. You did not need to buy a external hard disk. Both hard disks will work together and make total hard disk space- 1.25 TB.
Aug 04, 2010 | Compaq Presario 5000 PC Desktop
I can't find my hard drive. Where is is?
1) Depends on whether you are using an external or internal Hard disk drive
2) If it is external HDD, ensure that the USB cable is plugged into the PC for auto connectivity
3) If it is an internal HDD, You have to unscrew your metal case, look for the 3.5 inches in rectangular dimension metal device screwed onto your CPU casing. Ensure that there is a physical cable connection between the HDD to the Motherboard. The cable that will direct you to the HDD from the Motherboard should either be the SATA (Small Flat headed Red cable) or the IDE cable (white flat 24 pin cable)
On the HDD brand label there should be a Capacity size in MB or GB or TB, Cylinders, Heads and ensure that the poswer supply is connected to the HDD if it is an IDE HDD
Jul 29, 2010 | Computers & Internet
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? 2.is there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
Gigabyte GA-G41M-Combo Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
