How do you clean a hearing aid like phonak - Computers & Internet
  • 4 Answers
The answer depends on what model Phonak hearing aid you are referring to. In any case, the opening where the sound comes out (usually the part that fits to the deepest point in the ear) needs to be free of any debris (i.e., wax, dead skin, body oils, etc.). If the aid did not come with a cleaning tool (usually a little brush and/or tool with a tiny wire loop on the end), try buying cleaning tools in the dental care section of a Walmart or the like. Look for tiny brushes and picks normally used for cleaning dentures and/or braces. If you'd like more detailed and model specific instructions, please post a picture of the hearing aid you have.
Posted on Oct 12, 2013
Phonak Bolero b-p. What's the life of the battery (13) in normal use?
When your hearing aids adapt to every sound automatically, life is on ... Free yourself from the hassles of disposable batteries with Phonak Boleroâ„¢ B-PR - the ... What makes Bolero B so special is its unique operating system called AutoSense OS. ... Bolero B-P ... Moderate to profound hearing loss;Battery: 13 zinc air ...
Jun 07, 2017 | Cell Phones
Is the quality of Phonak hearing aid (same style) diff?rent if purchased from COSTCO than if purchased from a hearing specialist?
a hearing aid is programmed to your particular problem range so that those frequencies that you cannot hear are amplified so that you can.
why would you buy a hearing aid from a general store that is not going to have the ability to set the units to your hearing problem
Jan 10, 2017 | Health & Beauty
What does the signal Audio Jack on the hearing aid means
This can be used to stream music.
plug your ipod or mp3 into the 3.5mm audio jack socket and you can listen to music through your hearing aid.
Sep 18, 2016 | Phonak ComPilot
I can't get my compilot to work on my tv?
do you have a tvlink s basestation ?
http://www.phonak.com/com/b2c/en/products/wireless-accessories/products/tvlink-s/hearing-aid-accessory.html
http://www.phonak.com/content/dam/phonak/gc_hq/b2b/en/products/accessories/tvlink/_documents/User_Guide_TVLink_II_029-0313.pdf
Dec 23, 2014 | Phonak ComPilot
How do i use my blue tooth tablet to connct to my hearing aid via phonak i-com?
you need to go into the tablet settings and find the bluetooth settings most likely under network. then you need to add a bluetooth device.
at the same time you need to put the icom into pairing mode see
http://www.phonak.com/content/dam/phonak/b2b/C_M_tools/Accessories/iCom/Documents/com_icom_pairing_guide_others-xx.pdf
also see
http://www.phonetipsandtricks.com/tips/asus-transformer-pad-infinity-tablet/pair-with-bluetooth-speakers-or-headset-46/
if you need a code it will most likely be 0000
Nov 16, 2014 | Phonak ComPilot
My right hearing aid is 4 momths old and it stopped working
The Bolero model requires clear passage of sound through the tube that connects it to the dome/tip that fits into your ear. To determine if the tube is blocked, with a good battery inserted and the battery door closed, unscrew the top of the tube where it connects to the hearing aid. If you cup the hearing aid in your hand, it should whistle/feedback. If not, there is something wrong with the hearing aid. If it does whistle, your audiologist should have provided you with a thin, flexible plastic piece (often green) and instructed you how to unscrew the tube at the top of the hearing aid to run the plastic piece through the tube, all the way out the other end of the dome/tip. If that piece can travel the entire tube easily, then sound should be able to. In any case, a Phonak hearing aid has at least a one year manufacturer warranty (a Q90 likely has a three year) and they will pay for shipping both ways to fix it. You need to send it via an audiologist, though.
Jun 08, 2014 | Phonak Bolero Q90 BTE behind the ear...
My compilot will not charge, when plugged in no lights come on
is there a solution to phonak com pilots no charge no lights ??? where to get repaired
Feb 21, 2014 | Phonak ComPilot / TVLink S Bundled Package
Dual repeating tone in both aids
Your question is several months old, so I hope you've solved this issue. However, if not, please take the hearing aids to an audiologist for evaluation. It may only be an issue with the batteries you're using (be sure you're waiting 2 minutes after peeling off the sticker before closing it in the hearing aid), a moisture issue (very inexpensive hearing aid dryers are available at your audiologist), or the processor/circuitry may need resetting by the audiologist's computer. In rare cases of this symptom, a hearing aid processor has been overloaded by an outside electronic signal (i.e., MRI, etc.). Please see an audiologist for any of these possibilities.
Feb 18, 2014 | Phonak Audeo S Smart V
Distorted loud static sound consistantly on phonak unit one year old
Ensure the acoustic tubes are not obstructed. Detach them from the hard plastic flesh coloured part and clean them in warm soapy water, rinse and dry/allow to dry. Reassemble.
There is a possibility that this might be caused by the gain of internal amplifier being set too high, though this usually results in a constant or intermittent high pitched whine. Try adjusting the recessed wheel on the unit.
If neither of these measures cures the fault, you will need to take it to a technician, return to the supplier/manufacturer, or/and replace the unit
Aug 12, 2013 | Select Products Hearing...
Hearing Aid Compatability
Under ADA it is the employer's responsibility to make adaptations to your condition. Their radio provider should be able to provide you with hearing aid compatible headsets.
Jul 14, 2008 | Kenwood ProTalk UBZ-AM14 (14 Channels)...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
