Question about Vacuums
Dyson dc24 - just tried to use after being in storage, making loud noise and seems to be blowing out rather than in. Maybe a part missing? The hole at the top of the bin attachment is sucking air in.....should something be there to stop this?
    Problem Solver:
  • 18 Answers
The wand attachment at the top is supposed to only suck in when it\'s in the upright position, otherwise the suction should be used when the vacuum in rolled on the carpet/wood/surface.
If it\'s still under warranty, contact Dyson directly. This site may help: dyson.com/support.aspx
I hope that helps.
Boulder Epoxy Garage Floor
Posted on Oct 12, 2013
reddevil6
  • 1673 Answers
SOURCE: Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Posted on Jan 22, 2008
chrispurs1
  • 372 Answers
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Posted on Oct 16, 2008
SOURCE: Dyson DC14 Animal Vacuum - terrible loud noise
What I found was that it is the roller brush. If you are willing to get a little dirty and do it yourself, there is the roller brush that most likely needs to be cleaned. After a little tinkering of my own, the roller brush can be slipped out or just shift it out of place to clean it. There are two ends to the roller brush and the brush itself. Of you twist the two ends until the come apart you would probably find a lot of hair and other long strand items wrapped around the rod that goes through the brush. Once you clean that out it should work like new. If that does not work then it is probably the clutch which is what the belt around the roller brush is connected to. Hope this helps, it is a simple solution.
Posted on May 22, 2009
  • 83 Answers
SOURCE: he dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Posted on Jul 30, 2009
Dysonteam
  • 167 Answers
SOURCE: On my dyson DC24 the beater bar attachment is not
Hi its Darran at Dyson.
You may to simply re-set the brush bar. The cleaner head will automatically switch the brush bar off to protect the motor should the brush bar become obstructed. To re-set this, switch the machine off, stand it upright and locate the red re-set switch on the side of the cleaner head. Push this re-set switch in as far as you can and then switch the machine back on. Once lowered into the vacuuming position, the brush bar should start turning.
If this doesnt resolve the issue, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service.
Posted on Apr 22, 2010
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson Ball DC24 brush turns but is loose and makes a very loud noise. Brush seems to be hitting sides of vacume.
You need a new brush and end cap. The brush and end cap can wear or break in time as they are made of plastic. Spares available on Dyson web site.
May 21, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Hi. I have a DC 24 which when brush rotates makes a very loud noise. I have replaced the brush and side bar. The side bar appears very loose. The noise stops when I switch the brush rotation off. Any ideas...
I'm sorry to hear you're having difficulties with your DC24. If the cleaner head seems to be making an unusual noise during use, you may want to check all the parts are correctly assembled, and that the cleaner head and brushbar are free of obstructions. The video below may help in doing this.
If you've tried this and are still concerned about the noise, please get in touch with us directly, as we should be able to determine the cause of the noise over the phone, and provide further assistance. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will help if you have the machine to hand when you call.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 22, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson dc24 hose works fine however the head of the vacuume does not pick up anything (no suction) the brush is still working and i have cheacked for blockages and found nothing,the cylinder seems to...
I'm sorry to hear you're having difficulties with your DC24. From your description of the issue, it does sound as if the cleaner may be blocked. You may find it helpful to run through the checks shown in our troubleshooting guide, just to make sure you haven't missed anything:
http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
This should enable you to resolve your issue without further assistance. However, if you feel you need some guidance, it's probably best if you get in touch with us directly, so we can help you resolve this as quickly as possible. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Sep 26, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My DC24 Animal is a great machine, but when the beater brushes are engaged (during normal floor vacuuming) it makes an incredibly loud noise. It's spinning and sucking and I have checked for clogs...
Glad to hear you're pleased with your DC24. If you're concerned about the noise the cleaner is making when the brushbar is running, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting steps over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 07, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My dc 24 dyson red ball is making a very loud noise ive been told to check all the hose but im struggling to take to front part off where the roller is it seems to be picking up as the canister has dirt in...
You should be able to resolve this issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
If you're still having problems, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Apr 11, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
MY Vacumn seems as though it is not picking anything up. It is also making more noise than usual. I cleaned both the filters and looked to see if something was clogged. Maybe I am missing something. ...
Well check the entire system for dust blocking the air. If it's not in guarantee anymore try checking the main fan, it could be missing some parts. Also, check how much air is going out the vacuum
Feb 28, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuums Logo
121 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
