Question about Dayton Dryers
Is Dayton 2EAX4 whole house attic fan noisy - Dayton Dryers
  • gregory witt Jul 31, 2013
    I am looking to install a whole house fan and want to know if this is a quiet unit
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: capacitor
Here is a link to a distributor with fan specs : http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=3C325B&operator=refineSearchResults&originalValue=Dayton+Fans&searchIndexId=1&typeOf=
I do not know which specific motor is used on that fan ( that fan has been discontinued) however you can check out this link http://www.emotorpro.com/index.asp?PageAction=VIEWCATS&Category=280
and have a representative that sells Dayton products answer your question... Hope this helps you...
Posted on Sep 10, 2008
  • 63 Answers
SOURCE: New home owner with attic?/whole house fan on
most of these fans were set up on a thermostat, it will be in attic, just follow the wires from fan!
Posted on Mar 16, 2009
  • 430 Answers
SOURCE: I just bought a new motor and installed it but now
Centrifugal force.....If you replaced the motor only and not the blades, the blades are likely out of balance or possibly bent. Check for wobble and to see that the shaft is fitting tight inside the blade collar.If there is a bushing on the fan blade or shf itself, check it for play as well
Posted on Sep 13, 2009
SOURCE: Dayton Attic fan running backwards
If the fan blade is on properly, then you probably have the wiring reversed. If you connect a line from motor to red box wire, and other motor line to black box wire, it will turn clockwise. If you reverse the wiring it will turn counter-clockwise ;-)
Posted on Jun 01, 2010
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Creme colored know shaped like a whistle that the interior broke from the wall control on the Dayton Fan--where can I order a replacement?
If you cannot mend it otherwise or fix it up with a tinkering then the part is available only with Dayton.
So check up with their dealer or the serivce outlet if this is closer to you , or search the web for the nearest centre mentioning you area of resisdence.
Sep 24, 2010 | Dayton 7F67 Shuttered Attic Exhaust Fan...
How do you operate the whole house fan in order to save heat loss
make covers for garage opening with hinges open in summer close in winter .
Oct 07, 2009 | Heating & Cooling
Sep 13, 2009 | Dayton (2C373) Fan
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Capacitor
Sep 09, 2008 | Dayton Permanent Split Capacitor Motor Fan
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Dryers Logo
41 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
