HOW TO OPERATE / USE the SOMERTEK - EB0700 7" 4GB eBook
How do I read the ebooks on the sd card. The books show up. I press to open and it just opens another dialogue folder. HTML, contacts. Email and so on. But it won't open a book for me to read ?
Make sure eBook file are right format for your eBook reader app.
If yes- then open eBook reader app first, then find file and open it.
Feb 04, 2016 | Tablets & eReaders
Tip
How to Remove DRM From Kindle eBooks and Read on iPad Freely
"I recently purchased an eBook from Amazon ebook store. My sister asked me to share the eBook with her iPad. How can I do this?"- From Yahoo answer
Actually, it's easy to share the Kindle ebooks. Here I want to introduce two convenient methods to resolve this issue.
Method 1. Download Kindle App on iPad and sync the Kindle ebooks.
As we all know, the free Kindle ereader app is available on almost all devices and computer now. To read the kindle ebooks on iPad, you can download the Kindle ereader app from iTunes app store at first, then login with your amazon account. After that, you can sync all your purchased eBooks to this iPad automatically.
Now, your sister can read your Kindle ebooks freely.
Method 2. Remove DRM protection from Kindle eBooks
In the method 1, it requires you share all your Amazon account information with your sister. It's not appropriate for somebody. Then you can choose method 2.
As we all know, the reason that we can't read Kindle eBooks on iPad directly is that all Kindle ebooks are DRM protected and can be read on specific devices. But what would happen if we can strip the DRM from Kindle eBooks? The answer is apparent. We can read the eBooks everywhere we want.
Here I want to introduce the ePubor eBook DRM Removal and share the detailed steps with you.
Step 1. Add eBooks to this eBook DRM removal
Click Add button, then you can choose ebooks from local computer and import. Another way, you can also set the default library for Kindle ebooks at first. Click the "Settings" icon, and you can customize the Kindle file directory. After set, this eBook Converter will detect the kindle ebooks automatically for you.
Step 2. Choose output format
Click "Output" dropdown list, then you can choose any format you need. This eBook DRM Converter supports almost all common eBook formats, ereader devices, apps in the output. For reading on iPad, you can choose "Apple devices - Apple iPad" in the output.
Step 3. Click Convert to start eBook conversion
After conversion done, you can click "Open Folder" to find the converted eBooks.
That's all. So easy!
ePubor Ultimate Converter
on Jun 13, 2014 | Amazon Tablets & eReaders
Tip
How to remove DRM protection from Kindle eBooks
I like to read books via amazon kindle fire. It's much more convenient than reading traditional books. However, most content downloaded via Amazon kindle are DRM protected and can't be shared or changed to other devices. This requires an eBook DRM removal software to help us.
ePubor Ultimate Converter is the most suitable program if you need to remove DRM protection from Kindle ebooks. Actually, this ePubor DRM ebook converter can also deal with iTunes iBooks, Nook books, sony ebooks etc.
How to remove DRM from Kindle eBooks?
Step 1. Add Kindle ebooks to ebook converter.
Click Add button, then you can select the ebooks you want to convert. Please note that, you have to download the ebooks to your local computer at first, and have a valid license to read it.
Step 2. Select output format
Click "Output" dropdown list, then select the right output format you want. This DRM ebook converter supports a lot of ebook formats as output, like common eBooks: PDF, Mobi, Epub, devices: Apple devices, Amazon devices, Sony devices, Samsung, Nook etc.
Step 3. Start Removing DRM from Kindle eBooks
Click Start button to start removing DRM from Kindle ebooks.
If you lose the metadata of some ebooks, you can also click edit button to modify the metadata for each eBook file and add your own rate and comments.
on Apr 22, 2014 | Amazon Tablets & eReaders
I have a SOMERTEK 10-901 i want to connect to my tv and watch movies i have stored on it but my tv is not picking up the android
First off, do you have a smart television that is on your local area network in your home? Second is your SOMERTEK on the same network as the TV? If so, are you sure there is not an application required for the TV and Tablet to communicate? Your TV may not support auto detecting other devices on the network and using them as a media device. You will have to set your SOMERTEK up as a media streaming device to do so and then see if your TV can detect it. Look over your TV manual and check what options are available to allow streaming to it. There may be an application proprietary to the TV that you will need to download from the app store on your Android device as well. I hope this helps you.
Oct 13, 2013 | Computers & Internet
How do i download ebooks onto my ebook reader
you can download any Ebook from genuinemoney.info to your ebook reader. you need to go to this site next download ebook directly to your reder,if reder not support browser thn download ebook to computer next transfer it to ebook reader.
May 11, 2012 | E-Book Systems, Inc. GLOBAL MARKETING...
Tip
Tips: Enjoy PDF ebooks on iPad, iPhone for (Mac/Windows) users
eBook Readers make reading experience more pleasant. Hold eBook device like a book, for it carries as many of desirable content at your fingertips. In addition, it can also allow you to take notes, highlight message and easily access to the passages you need.
Both PDF and ePub are two of the most popular eBooks formats. Each of them has its own characteristics. Such as eBooks in PDF format can support Book-marking, however, ePub eBooks can't do that. ePub-formatted eBooks can be optimally viewed by the eBook devices, for ePub is specially designed for reflowable content. Whereas, the PDF format doesn't have the feature. Different eBooks applications have their preferred eBook format. For example, Apple iBooks app uses ePub format as eBook format.
PDF to ePub Converter is specially designed for eBook enthusiasts to convert PDF to ePub for perfect compatibility with their eBook devices, such as iPad, iPhone 4, iPod Touch, etc.
For Windows OS: PDF to EPUB Converter
Detailed guide: How to convert PDF to ePub, PDF to iPad, PDF to iPhone 4, iTouch, etc on Windows?
For Mac OS: PDF to EPUB Converter for Mac
Full tutorial: How to convert PDF to ePub for iPad, iPhone, iTouch with Mac PDF to ePub Converter?
on Aug 17, 2010 | Computers & Internet
Somertek remote control
Contact the nearest authorised service center for your brand TV to buy an original remote control.
Apr 27, 2012 | Televison & Video
I have a EBook-EB101 have it plugged in-how long does it take to charge before you can start useing it?
How do I operate the ebook I just got for Xmas? Ive had it plugged into the computer and cant get it to work. Nothing is showing on my computer.
I want read ebook on alfatel h1 mobile
I too have searched for PDF readers for china mobile.
But couldnt.
So, I converted the PDF file into TXT from "A-PDF Text Extractor".
After converting, I copied the TXT file into the Memory Card and opened it from E Book reader in H1. And it worked well.
Hope you'll try this.
Thanks.
Best of luck.
Oct 12, 2009 | Handmark Software MobileLists (950142) for...
293 people viewed this question
 Grubhead
Grubhead
