Question about Vivitek D510 Projector
My Vivitek D510 has a blue power light that blinks 6 times, then the lamp light blinks 3 times, What is that?
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: my vivitek d510 projector lamp is not turn on.
You need to check the power supply feed to the lamp circuit and if this is workingg fine check if there is lamp reset- hours used. Also if the filter is blocked remove and clean, check the fan and also the connections/connectors in the mother board.
If not there can be errors in the motherboard.
Posted on Sep 28, 2011
Vivitek d510 projector has the power button blinking 6 times then the lamp light blinks 3 times. What does that mean?
do the next test. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Vivitek Televison & Video
My vivitek d510 projector lamp is not turn on.
Sep 28, 2011 | Vivitek D510 Projector
Hi, i have recently replaced my projector lamp, as it would not power up when switched on the main led on the power button just flashed, after replacing the bulb the light continued too flash, i took all...
It could be the lamp life needs resetting or the filter life needs resetting. Hopefully so, otherwise it could be a faulty lamp module.
Good luck
Aug 02, 2011 | Vivitek D510 Projector
I can't get my Vivitek projector a d952hd model to show light anymore - it is only 6 months old and I doubt it is the bulb as it looks new and the image had not diminished at all in recent weeks - we...
hi,
All projectors have self dioganisng function. If there is any malfuction inside the projector it will indicated by the LED blinking. You have to inspect how many time the LED blinks or which LED lights condinuosly. LED meas the power light or the lamp light. Then only anybody can suggest you a better solution.
ok
Jun 21, 2011 | Vivitek D825MX DLP Projector
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Mar 10, 2011 | Vivitek D825MS Projector
The lamp turns on for a second and you can see the vivitek logo on the screen then it goes dark
some projector are normal like what what you mention...you need to connect a video source like computer or sound system that have a video output going to your projector...because if you power on the projector with out a video source you see only what you mention the logo of the projector..
Mar 10, 2011 | Vivitek D510 Projector
I am needing to verify if this projector allows for a widescreen image and what type of bulb does it use?
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
Dec 27, 2010 | Vivitek D510 Projector
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Vivitek D510 Projector Logo
43 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
