I NEED A TV CODE FOR CIELO TV - Televison & Video
  • Gloria Koch
    Gloria Koch Dec 23, 2013
    try 10812. It works for my Cielo but I have to select TV and use the Pwr button to turn it on and off. Everything else works from the Direct TV selection.
Code for a ge universal remote for a cielo tv
We have no library of these codes, please use the code search function of the remote control.
Oct 11, 2016 | GE Televison & Video
What is the code for my tv remote for cielo tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 29, 2015 | Televison & Video
Have 46 inch cielo need code to run dish tv remote. Help please even the installer has no idea and couldnt het it to work with dish. Now my tv remote won't work so now desperate to find a remote i ca
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
Sep 16, 2014 | Televison & Video
Why won't my cielo tv turn on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 14, 2014 | CIELO ROJO T3E46S1F 46" LCD TV 1920x1080,...
Need codes for cielo tv
0281,0288,0280. Try these codes. If you wish to get more; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Feb 07, 2014 | Directed Televison & Video
I needa code to program my comcast remote for a Cielo tv
2098.2058.2061,2004. Try these codes. If you wish to get more codes and other details check:
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 12, 2014 | Televison & Video
Need tv code, to give to Dish TV, for my new Cielo TV
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts
Dec 07, 2013 | Televison & Video
We have just purchased a CIELO brand TV and cannot get the codes to program the directv remote to it. It's a very new brand and made in Hong Kong from what I've been able to find out. I've done a lot of...
082,086,083
0029,0054,0091,0096
01946.01983,01998,01940
Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 14, 2013 | Televison & Video
Engine management light comes on on daewoo cielo 1996
sounds like an o2 sensor, but the first thing you need to do is have the engin code read at your local autozone this is free. the computer codes should tell you what is causing the problem
Jun 03, 2012 | Cars & Trucks
Televison & Video Logo
1,334 people viewed this question
Top Televison & Video Experts
Electro Med Services...
