Question about Amana DD01E DigiDoor Occupancy Based Energy Management Sensor for PTAC Air Conditioners
Digidoor 2 Rattles and makes weird noises when opening or closing, but worse when opening. I can see the driving belt has a lot of play on it
Weird Squealing Noise under the hood
Couple of thoughts -
1) a belt is slightly loose. not enough tension it could be slipping.
2) when you had the belts replaced, the new ones could have been over-tensioned, which could wear out a pulley bearing.
Jan 09, 2014 | 2006 Nissan Sentra
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Whirlpool GGQ8831L rattles and makes loud noise??
The belt tensioner roller and the belt will need to be replaced
May 20, 2010 | Dryers
LG DLG2526W it just started to make a weird noise unitl it wouldnt spin anymore. unplugged it but still wont spin
The belt for the drum has a tensioner to keep the belt snug while running. The tensioner has a roller that incorporates a bearing to make it run smoothly. When the bearing goes bad the roller binds receiving a flat spot on it so when it turns it makes the belt snap very quickly making the belt to slap the drum everytime. It does make a lot of noise I know for I heard a lot of them with this problem. No since it does not turn the belt has finally broke so you need a tensioner roller and a belt which are sold together by most manufacturers
Apr 05, 2010 | Dryers
Bad Problem with solenoid valve.
If the valve noise is excessive, or more than it was originally, then yes, replace the valve.
If the noise is no worse than it was originally, then you may be overly sensitive to the noise its making.
Also, check that the valve has not shifted slightly in such a way that it's opening and closing rattles it against something that it didn't used to rattle against. A sheet metal panel will amplify the valve opening and closing.
Let me know what you find.
Dec 12, 2009 | Honeywell Power Humidifier: Furnace...
Same thing but with noise
This is more than likely your laser that is dead or dying and its possibly a samsung or hitatchi drive, be
careful when buying a new laser because there is a lot of dodgy ones around at the minute which can damage
your machine or at the very least will be inferior and not last long.
It could also be the logic board or the drive belt too, if the logic board is faulty no matter how many lasers
you try it will do the same, the fix is to replace the logic board.
if its the drive belt well this is very easy to try and is what id try first, open your 360 tray and look
inside the 360 you should be able to see the drive belt, make sure its attached properly and then take this
out. replace it with a new one and see if this recifies your problems.
SOMETIMES if a drive belt is stretched it will not close properly and then a fault like yours will occur. its
all a matter of eliminations. Drive belts can be found on ebay.
Linda.
www.XboxRepairKit.co.uk
Sep 06, 2009 | Microsoft Xbox 360 Console
2002 chevrolet silverado 2 wheel drive that rattles when you drive down a bumpy road. It seems worse when you first take off in the morning, but after you drive it for a while the noise seems to not be as...
Personally, I would start looking at the exhaust system shields and hangers. Make sure they are secure and not too close to the exhaust components. Minimum clearance for the shields is 20mm ( roughly 3/4"). You might be able to get away with a little less, but move or bend to get additional clearance.
Also make sure the spare tire rigging is secure, always a culprit.
Let me know how it goes,
Regards,
Feb 25, 2009 | 2002 Chevrolet Silverado 1500HD
Amana DD01E DigiDoor Occupancy Based Energy Management Sensor for PTAC Air Conditioners Logo
65 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
