Question about Garden
Motor is spuddering its a pressure washer motor
    Sergeant:
  • 402 Answers
Has it been stored in the garage with fuel in carb if yes clean the carb
Posted on Aug 05, 2013
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Spudders and will not revup
A mechanic would check the air cleaner and the fuel pressure.
Is the check engine light on ?
Aug 26, 2012 | Hyundai Motor 1998 Accent
Pressure washer pump pressure kills gas motor
the pressure regulator valve is stuck take it apart and clean it
Jun 04, 2012 | Annovi Reverberi Sjv3g27d Pressure Washer...
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
I have a k7.91 pressure washer the motor runs but stops or pulses
This sounds like a problem with the pressure sensor which is located on the water inlet side of the pump. This switches the power to the motor when there is sufficient inlet pressure and water flow. This pressure switch can get partially siezed up, and not operate correctly.
You will need to dismatle the unit and identify the pressure switch, dismantle it and lubricate it with silicone grease.
Feb 28, 2010 | Karcher PSI Electric Pressure Washer
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Karcher k7.91 pressure washer /loss of pressure
if the motor will not turn on ,thers a problem with the current excess switch , which is situated under the main power on of swith hi needs to be replced
May 04, 2009 | Karcher PSI Electric Pressure Washer
2004 cavalier spudders
Sounds like a plugged exhaust system to me... check the tailpipe... try to smother it with your hand while wearing a oven mitten. You should feel pressure building up... check the feel of the pressure with another vehicle. Mufflers do come apart inside and pieces get stuck in the tail pipe forcing the engine to idle or even just stall out... In this case you are fortunate to get 10mph. Good luck....
May 02, 2009 | 2004 Chevrolet Cavalier
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
