Question about Vivitek Televison & Video
Vivitek d510 projector has the power button blinking 6 times then the lamp light blinks 3 times. What does that mean?
    Top Expert:
  • 12,223 Answers
Do the next test. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Aug 01, 2013
SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Posted on Jan 12, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
rockitman187
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
My vivitek d510 projector lamp is not turn on.
You need to check the power supply feed to the lamp circuit and if this is workingg fine check if there is lamp reset- hours used. Also if the filter is blocked remove and clean, check the fan and also the connections/connectors in the mother board.
If not there can be errors in the motherboard.
Sep 28, 2011 | Vivitek D510 Projector
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Hi, i have recently replaced my projector lamp, as it would not power up when switched on the main led on the power button just flashed, after replacing the bulb the light continued too flash, i took all...
It could be the lamp life needs resetting or the filter life needs resetting. Hopefully so, otherwise it could be a faulty lamp module.
Good luck
Aug 02, 2011 | Vivitek D510 Projector
I can't get my Vivitek projector a d952hd model to show light anymore - it is only 6 months old and I doubt it is the bulb as it looks new and the image had not diminished at all in recent weeks - we...
hi,
All projectors have self dioganisng function. If there is any malfuction inside the projector it will indicated by the LED blinking. You have to inspect how many time the LED blinks or which LED lights condinuosly. LED meas the power light or the lamp light. Then only anybody can suggest you a better solution.
ok
Jun 21, 2011 | Vivitek D825MX DLP Projector
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Mar 10, 2011 | Vivitek D825MS Projector
The lamp turns on for a second and you can see the vivitek logo on the screen then it goes dark
some projector are normal like what what you mention...you need to connect a video source like computer or sound system that have a video output going to your projector...because if you power on the projector with out a video source you see only what you mention the logo of the projector..
Mar 10, 2011 | Vivitek D510 Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
I am needing to verify if this projector allows for a widescreen image and what type of bulb does it use?
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
Dec 27, 2010 | Vivitek D510 Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
Televison & Video Logo
225 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
