Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
I use powerbook G4 Laptop and i can't boot to the desktop.when i put on the laptop i see the finder icon with a question mark on it. what may be the problem
    Champion:
  • 220 Answers
Most likely is hard drive. may need to be replaced.
Posted on Oct 19, 2013
minteker
  • 52 Answers
SOURCE: How to boot PowerBook G4 with damaged display
Download and install "Screen Spanning Doctor" for mac (freeware, great prog). Use clamshell mode (see readme). Hook up external monitor (DVI out?). Boot normally... Keep shell closed. Works for me :>
Posted on Mar 11, 2008
mattozan
  • 555 Answers
SOURCE: Need Mac G4 laptop schematic manuel
Not sure if you want an actual circuitry schematic, or a internal parts guide.
A manual for field-replacing just about every component inside your Powerbook can be found here.
I expect that circuitry schematics are much harder to come by, and are actually likely to be protected by trade secrets.
Posted on Apr 03, 2008
thehumble1
  • 137 Answers
SOURCE: Powerbook G4 wont start up, shows a file folder with a ? mark....
The hard drive is probably on it's way out. You can get and run Disk Warrior and you could repair permissions and such but the hard drive is probably on it's way to the grave.
A couple things though. It isn't enough to just put the disk in, you need to hold down "c" while the computer starts for it to try to run off your disk. You can then try to repair permissions and fix the disk from the installation program that starts. When the Install OS X screen comes up (looks like a desktop but with the big dialog box in the middle) click on Utilities at the top and then on Disk Utility. HERE IS APPLE'S SITE for you to read about how to try to repair your disk. I've found that this sometimes works and may help it work enough for you to get your files off, but may not.
Another method would be to get another Mac, and hook the two together with a firewire to transfer your files, then reinstall OS X in your ailing computer. Go HERE to read about this technique.
Posted on Feb 26, 2009
  • 40 Answers
SOURCE: apple laptop won't turn on
Try to boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot.
If so run disk utility from the cd and repair the disk as well as permissions.
If this is successful your computer "should" be repaired. If it still has problems booting, Use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Posted on Mar 01, 2009
thehumble1
  • 137 Answers
SOURCE: PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Posted on Apr 17, 2009
Ibook g4 won't open just gets a flashing equation mark and the finder icon
Sorry, either your hard drive cable is loose or your hard drive has died.
Mar 10, 2013 | Computers & Internet
I am trying to switch on my g4 notebook. And am presented with a folder icon bearing alternately a finder icon and ? Any ideas?
Your mac cannot find an operating system. Re-install the operating system using the 2 discs Apple gave you. If that don't work, then you need a new hard drive. 2.5" 120 GB laptop hard drive IDE/ATA are the specs you need. If it says SATA, then you got the wrong hard drive.
Sep 05, 2010 | Apple PowerBook G4 Mac Notebook
I changed the hard drive in my powerbook g4 17in how do i in stall snow leopard on it it has a folder with a flashing question mark and finder
It seems that snow leopard is only installable on macs with intel processors, and yours is PowerPC.
see more here: http://www.apple.com/macosx/specs.html
Aug 23, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My powerbook g4 is not starting. it opens the gray screen and just says i need to restart the computer. i tried restarting it and removing the battery a bunch of time and nothing is happening. HELP!!!
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Powerbook G4 to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Powerbook G4 and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
At times this procedure does help for gray screen issues so give this a try and let me know if this helps.
Thanks!
-Mactechtrainer
Jan 25, 2010 | Apple PowerBook G4 Mac Notebook
When my imac g4 tries to bootup it shows a folder icon
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Oct 03, 2009 | Apple iMac G4 Desktop
Apr 16, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Issues loading software on powerbook G4
Try using the finder to locate your software packages and simply relocate their icons to the applications folder by opening several new finder windows and dragging and dropping them there.
If you, in fact, went through each application's setup, then the icons were created somewhere on the disk, perhaps on the desktop or even above the desktop, external to the particular user.
Try locating each package back to the applications folder.
Apr 07, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
G4 15" powerbook desktop disappears and reappears every 30 sec
hello
this looks lik a conflict with you extensions or fonts. Please hold the shift key at startup for 15 seconds and see what ot does.
Mar 14, 2009 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
Powerbook g4 not detecting newly installed combo drive, no icon on desktop
Do you have the origional apple restore media?? If so try to boot from this disk to see if its an OS problem or a hardware problem.. Curious why did you replace the drive ?? Is this the same issues that you had prior?
Nov 06, 2008 | Computers & Internet
Apr 03, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
85 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
