Question about Maytag Bravos XL High-Efficiency Electric Dryer
Replacing pulley on Blower Housing
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of the blower housing, but can figure out how to get to it to replace it.
    New Friend:
  • 24 Answers
If there is no access panel on lower right side behind machine, you will have to lift the top of the machine from the front and remove the front panel to access the inside of the machine. While there it would be a good idea to check out the drum rollers if present and drum glides for wear. Also make sure that the blower wheel is not loose on the motor shaft. All of these will cause noise issues and are common.
Posted on Jul 31, 2013
Blower motor belt
It could be belt or belt idler problem or rollers or drum has twist on it or motor pully issues .
Every part of dryer drum and motor pulley and idler and belt should be examine and run dryer without top and check it with load and without load and try to isolate problem
Dec 06, 2013 | Maytag Bravos Series MEDB850WQ Electric...
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer does not heat all the time
have you took it apart and inspected the blower belt? It may have come off. The blower pulley falls off on these. PHOTO
Dec 17, 2012 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Maytag bravos will turn on; totally dead, its plugged in properly and breaker is connected
Bravos dryer picture
Bravos service manual
A lot of these are malfunctioning due to the small belt and pulley that drives the blower falls off. It is recommend lock tite on the nut will fix the problem.
Sep 22, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos dryer Model # MEDB850WQ0 Just gave my right arm to gave a service technician put my slipped fan belt back on my dryer. He wouldn't show me how to disassemble the unit if it happens...
Hello, Thank You for using FixYa. I will be helping you today.Use a putty knife to push in the lock tabs just under the lid or top in each corner push in firm and lift the top. When the top is open there are two screws one on each side holding the front on remove and lift the whole front. That's it....And if its the blower belt that comes off we are suppose to put locktite on the pulley to stop that from happening..
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Bravos dryer heats but does not blow air out the vent.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Jan 11, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Aug 18, 2009 | Maytag Dryers
Maytag Bravos XL High-Efficiency Electric Dryer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
