Question about Canon LaserClass 9000L Plain Paper Fax
Print verification report - Canon LaserClass 9000L Plain Paper Fax
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
(OK). If you choose On or On+Image, the report will print for every fax you send.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
When the Transmission Verification Report is turned Off or Off+Image, the Report will
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
HOW TO PRINT CONFIRMATION PAGE
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Need fax confirmation report .
1) Press <Menu>
2) Press Up or Down <Arrow key> to select "Fax"
3) Press <OK>
4) Press Up or Down <Arrow key> to select "Report Setting"
5) Press <OK>
6) Press Up or Down <Arrow key> to select "Transmission" or "XMIT Report"
7) Press <OK>
8) Press Up or Down <Arrow key> until the option you prefer appears:
  • OFF - Transmission verification report will print only if a fax is unsuccessful
  • OFF+IMAGE - Transmission verification report will print if a fax is unsuccessful with a portion of the fax first page
  • ON - Transmission verification report will print after every fax transmission
  • ON+IMAGE - Transmission verification report will print after every fax transmission with a portion of the fax first page
9) Press <OK>
10) Press <Stop/Exit>
I hope this helps!
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
Intellifax 770 print transmission verification report for multipl
You can print an activity report by pressing FUNCTION, 7, 2, START. That will give you the last 30 faxes sent and received, It will only show that you dialed though, it will not be a true verification report. In case you need it, you can download the manual for your fax here:
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Dec 05, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Stop Transmission Verification Report on Brother 2820
It should be under the REPORTS section of the menus.
Step through the menus to turn off CONFIRMATION REPORTS.
Sep 30, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800
Hit the "Reports" button. Then hit the "4" button which is the transmition report. It will then print the verification of the transmition.
Sep 05, 2008 | Brother IntelliFAX 2800 Laser Fax
Avoid printing Transmission Verification Report
You have to change the fax menu settings. Here you can compute the machine to avoid the error reports (see manual chap. fax settings)
Jan 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon LaserClass 9000L Plain Paper Fax Logo
old marine
old marine
