Question about Maytag Dryer. Bravos XL 7.3 cu. ft. Electric Steam Dryer in Granite
Maytag Bravos XL Model - how to replace belt pulley on the blower housing.
jsrock516
  • 5911 Answers
SOURCE: Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: How to route belt around pulley and idler
repairclinic.com
Controlfrk
  • 304 Answers
SOURCE: i need help replacing maytag dryer belt model
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
Belt Configuration
Posted on Nov 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
marka19
  • 1430 Answers
SOURCE: Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Posted on Apr 09, 2010
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Dec 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Blower motor belt
It could be belt or belt idler problem or rollers or drum has twist on it or motor pully issues .
Every part of dryer drum and motor pulley and idler and belt should be examine and run dryer without top and check it with load and without load and try to isolate problem
Dec 06, 2013 | Maytag Bravos Series MEDB850WQ Electric...
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Replacing pulley on Blower Housing
If there is no access panel on lower right side behind machine, you will have to lift the top of the machine from the front and remove the front panel to access the inside of the machine. While there it would be a good idea to check out the drum rollers if present and drum glides for wear. Also make sure that the blower wheel is not loose on the motor shaft. All of these will cause noise issues and are common.
Jul 31, 2013 | Maytag Bravos XL High-Efficiency Electric...
Dryer does not heat all the time
have you took it apart and inspected the blower belt? It may have come off. The blower pulley falls off on these. PHOTO
Dec 17, 2012 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Maytag bravos will turn on; totally dead, its plugged in properly and breaker is connected
Bravos dryer picture
Bravos service manual
A lot of these are malfunctioning due to the small belt and pulley that drives the blower falls off. It is recommend lock tite on the nut will fix the problem.
Sep 22, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Gas dryer runs and heats but won't blow air
Hello, Thank You for using FixYa. I will be helping you today.The belt for the blower came off and most likely the pulley.If the pulley came off put locktite on it before installing the pulley to prevent it from happening again.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Maytag Bravos dryer Model # MEDB850WQ0 Just gave my right arm to gave a service technician put my slipped fan belt back on my dryer. He wouldn't show me how to disassemble the unit if it happens...
Hello, Thank You for using FixYa. I will be helping you today.Use a putty knife to push in the lock tabs just under the lid or top in each corner push in firm and lift the top. When the top is open there are two screws one on each side holding the front on remove and lift the whole front. That's it....And if its the blower belt that comes off we are suppose to put locktite on the pulley to stop that from happening..
Jun 14, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
May 02, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos dryer heats but does not blow air out the vent.
Jan 11, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Dryer. Bravos XL 7.3 cu. ft. Electric Steam Dryer in Granite Logo
100 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
