Question about Logitech Wireless Headset H600 - headset
My headset echoes and its very distracting how do I get rid of it?
Logitech G930 Echo problem
Check the device manager for duplicate devices and make sure that the on board devices are disabled
Dec 09, 2013 | Logitech G930 Wireless Headset
Every time i go into any live chat it echos for ever and never stops it unbearable i don't use them for chat ever my friends can't stand it
I found this on the Turtle Beach website: __________________________________________
If you or other players hear echoes in Live Chat:
Does it happen if you use the Microsoft communicator? Mute the microphone on your headset. Does the echoing stop? In the Xbox Dashboard > Settings > Live, set the voice to Play Through Both and unplug the talkback-controller cable. Does the echoing stop?
Echoing can sometimes be caused by high latency ("lag") on your internet connection. This may come and go depending on how much bandwidth is being used in your area.
If your talkback-controller cable's plug gets dirty, this can also cause echoing or static. Also check the input jack on the controller and make sure no foreign objects are in there.
Read these links for more advice:
Echoing can be caused by "a poor connection between the headset and the controller." http://support.microsoft.com/kb/912493 "The most likely cause is either a plug that isn't pushed all the way in, or gunk on the plug." http://xboxelle.spaces.live.com/Blog/cns!1pUP4M-J1d781v7Ac0Ta8FDw!158.entry "If you hear echo, then... someone in the chat session... needs to clean off their metal headset plug." http://majornelson.com/archive/2005/12/25/get-rid-of-voice-echo.aspx
Dec 24, 2009 | Microsoft Turtle Beach X4 Dolby Digital...
When i move the cord on my turtle beach x1 it gives me static and the mic echos when people talk. any ideas?
Nov 30, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Outside caller hears themselves in an echo
Jan 23, 2009 | Plantronics CS55 Wireless Headset
Motorola H3 headset. Echo and Squeal.
The echo is unfortunately a common problem with the Motorola H3 headset. I have one of those sitting in a drawer somewhere because it echoed with every phone I paired it to. After buying the H3 and experiencing the echo, I read reviews. I should have read the reviews first. Lots of people get the echo and there doesn't appear to be any fix. I guess that's why I got the headset, a leather case, and a car charger in a kit for just $20.
Jul 03, 2008 | Motorola Mobility H3 Bluetooth Headset,...
Echo
MOVE IT AWAY, AS FAR AS POSSIBLE, FROM OTHER ELECTRIC DEVICES
Feb 04, 2008 | GE 25932 Cordless Phone
Echo when using HS850
It might be a problem with their sound setting. If their speakers are on while using the mic, they might get some feedback that could be the cause of the echo. They may even just have to tweak their mic settings (through the control panel sound options or their soundcard options).
Jan 06, 2008 | Motorola Mobility HS850 Consumer Headset
Using Nokia CK - 7W bluetooth handsfree with Motorazr v6
You will have echo when using phones that are not Nokia.
Dec 17, 2007 | Motorola Mobility MOTORAZR maxx V6...
Echoing
lower the volume of your mic.
Nov 15, 2007 | GN Netcom GN 8000 Amplifier
Logitech Wireless Headset H600 - headset Logo
44 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
