Question about Dell Precision 390 PC Desktop
I have a dell precision 390 and i took it apart to clean the dust out of it and after all that was done i put it all together and now the workstation is not powering on. on the motherboard the power indicator light shows that the system is recieving power
  • Adam phelps Dec 15, 2013
    it works now thank you
    Scholar:
    New Friend:
  • 142 Answers
Loose wire, or some dust in a connector. Take it apart again, clean it out again and put it together again. Post again if still not working.
Posted on Dec 12, 2013
the_fire
  • 432 Answers
SOURCE: Dell Precision Workstation 670
Try different memory modules ( RAM ) and see if it is just the RAM.
Also take anything else out you dont need - including dedicated graphics card assuming it has onboard graphics card ( if so then enable the onboard graphics card before taking out the dedicated one )
If its still the same then yes it is the motherboard in which case you need the motherboard replacing.
If you did the diagnostics that they walk you through and they still tell you its the motherboard then it will be the motherboard as there diagnostic software is accurate.
Posted on May 06, 2009
  • 3940 Answers
SOURCE: I have a broken Dell Precision 470 Workstation.
sounds like a motherboard failure.
Basic troubleshooting, disconnect all external connections except power, see if indications change, if no go remove all expansion cards see if any change, if no go disconnect all drives see if any change. If none, then motherboard.
If at any step you get a change in indications, then see if you can isolate the faulty item
DIAG LED info is here
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Posted on Jun 16, 2010
  • 3940 Answers
SOURCE: About Dell precision 450 workstation is Dell
A precision workstation is a high performance desktop system. The 450 is an older model but can still do well as a desktop system
Posted on Jun 17, 2011
atang1
  • 734 Answers
SOURCE: dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Posted on Dec 07, 2011
sirlouis009
  • 91 Answers
SOURCE: Hi im trying to fix a dell precision 390 and it was working fine then one day i go t power up and nothing there is a yellow light on mobo so power is going there but psu is dead and nothing else power
yes, first check the power, and the memory (i.e. simm)
Posted on Mar 07, 2012
DELL Precision WorkStation 390 6GB installed but show 3GB usable
your system uses 3 gb,you havent lost anything you have 3 gb dedicated ram and 3 gb useable ram
Apr 04, 2015 | Dell Computers & Internet
Where can I get a recovery disk
Diane Crump,
Dell never supported windows 7 on this system.
You will need to do a search on online for a Windows 7 Pro Disk.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 28, 2015 | Dell Precision 390 Workstation Core 2 Duo...
Bios reset
If BIOS doesn't recognize CD Rom or USB, I would try updating the BIOS first. It is available at the link below. You may want to update the other drivers as well.
Dell Precision System BIOS 2 6 0 Driver Details Dell US
Apr 06, 2014 | Dell Precision 390 Workstation Tower,...
Is it possible to upgrade the mother board in this computer?
Dell Cases are very often only for Dell boards--connectors not standard--It can be done,but a lot of trouble. If you want to really speed up look for good complete kit from tigerdirect.com--and put it together--Will work A LOT better than what you can buy at stores.
Jan 31, 2014 | Dell Precision 390 Workstation Tower,...
My Dell Precision Workstation 690 can not boot from the Disk
try this clean it whit a brush in the tracks never ower .clean the CD-WRITER/PLAYER with caned air.
Apr 08, 2013 | Dell Precision Workstation 690 -1KW Dual...
Have purchased 512GB Crucial m4 2.5" SSD for my dell precision t7500 work station will it be working
make sure that your Dell's specs are in line with this drive. if you buy memory or hardware that is newer than the machine it is made for, chances are the technologies will not work together. so you should only replace hardware that is(will) compatible with the generation of PC you put it in.
Jan 24, 2013 | Dell Precision T7500 Computer Workstation ...
Dell precision 490 led 4 remains on
try to clean the memory slot of your computer as well as the memory module then power up your PC. just do hardware maintenance by means of cleaning all any dust inside the computer. Hope it helps thanks.
Nov 02, 2011 | Dell Precision Workstation 490 - MT -...
About Dell precision 450 workstation is Dell precision 450 workstation use as desktop PC. thanks
Jun 17, 2011 | Dell Precision 450 PC Desktop
How do I get the second hard drive out of a dell precision 670
Hello there. before going into the Case make sure to touch the metal
Power down the PC and remove all cables
Open the side of the Case find the hard drive you want to remove unplug the two cables connecting to the hard drive and slowly remove the hard drive from the bay you may need to UN-screw the hard drive.
put in the new drive into its bay connect both cables put the case back together connect all the cables back to the PC boot the System up and reformat the new drive .
If you need anymore help with this problem let me know, i have done it many times myself thank you and don't forget to Rate
Jan 26, 2011 | Dell Precision Workstation 670 PC Desktop
Dell Precision 390 PC Desktop Logo
91 people viewed this question
Alun Cox
