Question about Kitchen Ranges
Whirlpool built in electric convection oven model GBD277 after clean mode oven will not unlock and seem to have no power. Have checked the circuit breakers all is fine but still oven seems to have no power. Nothing lights up on panel?
4 Suggested Answers
  • 1073 Answers
SOURCE: I have a KitchenAid Superba
there is a one time blow fuse in the back of the oven, unfortunatly you have to pull the wall oven out of the cavity to get to it
Posted on Apr 25, 2008
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
GodBlessU
  • 3513 Answers
SOURCE: Maytag model JDS8850BDB dual fuel
Hi
Most likely the problem is going to be the touch pad, which comes on one way, which is the whole control panel. You need to replace that. Or try unplugging the machine from the power outlet, wait for a minute and plug it back in.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 18, 2011
Top burners OK. On convect bake the oven will heat up to set temperature then shut off and cool down. Normal bake function seems to work ok.
PDF]BUILT-IN ELECTRIC CONVECTION OVEN - Whirlpool
https://www.whirlpool.com/.../Use%20and%...
Whirlpool Home AppliancesBUILT-IN ELECTRIC CONVECTION OVEN. Use & Care Guide ..... To Turn TonesOff/On: Touch and hold COOK TIME until a tone sounds and the lower oven ...
Teach me how to use my convection oven - Chowhound
Jan 01, 2016 | Maytag MES5875BAS Slide-In Electric Range...
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
Built-in Whirlpool model GBS307PRS01 oven won't get hot
First check the thermal fuse to see if it's open circuit and if so replace with http://www.appliancepartscompany.com/product/9223815
This is normally the problem (I have already replaced it twice on my oven).
If this doesn't solve your problem, let me know as there are some other option to try.
Jul 08, 2010 | Whirlpool GBS307PRS Stainless Steel...
Elextrolux Range stuck in Demo Mode
Phone agents and ask for workshops. Quote them the model and problem you have.
Jun 06, 2010 | Electrolux 30" Self-Cleaning Slide-In...
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Jun 10, 2008 | Ovens
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
