Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
Dishwasher does not clean dishes most times
  • 6 more comments
  • oleeva Sep 20, 2008
    Top tray and epecially the silverware tray are not cleaned well
  • climgkua Nov 18, 2008
    I have the same issues with dishes not getting cleaned.
    Happaned right after on year warranty expires.
    Does anyone have a similar expereince and how to go about it?
  • lungert Dec 21, 2008
    I have the same problem also. I had someone come to look at it but they said there is nothing wrong with it. Top rack especially is not clean
  • mlegraphics Dec 27, 2008
    My dishwasher doesn't work anymore either and I agree... it is especially noticeable with the top shelf i.e. the glasses.  Is there a filter that needs to be cleaned out?  We had a repair man here about 3 years ago and I seem to remember him saying something about a filter or an area of the dishwasher that collects any loose food debris that comes off the dirty dishes, but since it wasn't the reason he was here, and he never actually showed us this filter or area, I don't know where it is.  Can someone please advise?
  • flanneljeans Dec 29, 2008
    I have the same problem on my kenmore 15930 Elite dishwasher. The upper rack doesn't seem to be getting clean (slowly getting worse over a long period of time). Here's what I've done/figured out so far:
    1. Water pressure is fine. I can't understand why this would make any difference. The water is added to the dishwasher, then just recirculated inside by the pump. External water pressure has no effect as far as I can telll.
    2. No blockage in hoses. Water comes in fine. Water is drained back into the disposer fine. Hose to upper sprayers is free and clear (I took it off and checked)
    3. Using a screwdriver, I manually shut the open/close switch on the door, and turned on "quick rinse" mode while watching through a partially open door. The lower sprayer turns and works fine. The upper sprayer has water shooting out the holes, but turns 2 or 3 times, then stops. The water shooting out of the upper sprayer does not reach the top
    I believe for some reason, not enough water pressure is being generated to have the upper sprayer hit the top and continue to turn. I believe this has been happening for some time, as you can see residual stuff clinging to the roof of the tub and the sides near the top. Since I find it hard to believe that the pump is just less powerful than when it was new, I'm wondering if there might be a blockage in the water path from where it is sucked from the bottom of the tub, back through the pump? I notice there is a fine screen mesh that covers the intake, but that does not seem clogged.
    Any thoughts are appreciated. Thanks.
  • pjkmitchell Jan 06, 2009
    Yes, exactly the same problem. Argh.
  • lrath Jan 11, 2009
    I have the same problem with a Kenmore 15874 model. There is water in there getting just to the heating element, and the bottom shelf is getting clean. The top barely looks like there is any water sprayed on it. I took apart the hoses going to the top sprayers and ran water through them with no problems. I looked in the lines and found nothing. I even took apart the bottom and looked in there and found nothing. Any ideas?
  • westfordus Jan 13, 2009
    I have a f&p the top drawer does not clean the dishes well, the bottom works perfectly. I have noticed the dishwashing tablet has started not to fully disolve the last few time I have tried to use the top. I have run it empty, run it with vinegar, with bleach, taken every removable part out and cleaned it but no resolution. Any suggestions?
  • 25 Answers
Easy to take apart.. (the water recirculation area needs cleaning)
lots of **** gets down in there and doesnt flush through - olive pits, straws, toothpicks..
1) get a pair of gloves and a star set of screwdrivers (or those T hex thingys - about 8 bucks at the home depot for all sizes)
2) flip the breaker to 'off'
3) open the door, remove the racks (the bottom one just comes out easily, the top one has two endpeices on the rails that need to be CAREFULLY removed - they're plastic and they WILL break
4) remove the bottom sprayer (should be able to do this without tools but a set of pliers comes in handy) - once removed, rinse it out making sure all the little holes are free of debris
5) remove the top sprayer feeder tube (this un'clicks at the back of the dishwasher wall and then rotates about 45degrees left (counterclockwise) to unlatch itself from the bottom thingy.. this may have a bunch of crud in it as well.. use whatever pipe cleaner type gadget that you may have to clean this out (dont use bleach)
6) remove all the screws on the bottom big filter.. (clean out all the **** once its out
7) BE CAREFUL NOW - THERE MAY BE BROKEN GLASS DOWN IN THIS AREA - now there's a little filter area on the front side of the 'hole' reach in with your gloves and clear all the debris out.. my guess is that if you have had this for a year or so, it will be filled with debris.. once this is cleaned out, that filter thing comes out as well (i think i remember there being a couple of those THex screws holding this think in as well)..
8) make sure all debris, tools etc are out of the dishwasher..
9) with everything disassembled and out on the counter, flip the breaker back on and run a rinse cycle to make sure all is clear... (it will most certainly be louder now that the waterflow is clear)..
10) assemble all back in reverse order and load up..
i'm not a repair guy i just like taking things apart and seeing what makes them work - you will save 200 in repair fees (min) by doing this yourself (if you're not afraid of touching a little bit of crud.. lol)
have fun and enjoy the sense of accomplishment..
tpug
Posted on Jan 24, 2009
    Scholar:
  • 173 Answers
Dishwashers need alot of water ..check hoses for blockage and water pressure...should be around 40. also check and see if proper drainage. water has to get to the top by hoses to a sprayer check that...a motor has to run the sprayer,that looks like a 2 blades whirling about with holes, and might have clutches and gears worn in that cycle...you will stand there and hear all the cycles and can open it to see if top gets water. good luck
Posted on Aug 31, 2007
5 Suggested Answers
  • 300 Answers
SOURCE: Silverware and dishes not getting clean, leaving grit on dishes
It cleans poorly If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Mar 07, 2009
  • 1075 Answers
SOURCE: dishwasher is not cleaning dishes
i would suspect spraying arms or water temp not working.adrian,,,
Posted on Jul 14, 2010
taran_2005
  • 10515 Answers
SOURCE: We have a kitchenaid dishwasher,
There are 6 major reasons that could affect the cleaning.A nice guide you could follow is :-
http://www.partselect.com/dishwasher+dishes-not-clean+repair.htm
Other than this, you need to check the pump. Make sure that it is not clogged.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: bosch dishwasher not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
wyt42
Posted on Sep 29, 2010
Dishwasher not cleaning dishes
If it is a cheaper brand/model of dishwasher, you may have to rinse the dishes, especially if they have been sitting for a while. While there are dishwasher who are powerful enough to clean even crust off the dishes, most need to have the dishes rinsed off even just with cold water right after use....If you do not use alot of dishes per day and let the washer build up dishes after a few days then I would recommend a warm/hot water rinse even with a dish sponge and some soap. While some may think that this defeats the purpose of using a dishwasher, remember that a dishwasher is more sanitary that using a dish rag or sponge that had the opportunity to build up bacteria and other gunk over a period of time ;-)
Aug 28, 2013 | Kenmore Dishwashers
Leaves a white soapy film on pots, pans and dishes
Are you overloading your dishwasher? Are you loading the dishes in such a way to cover the water shooting up from the blades? Have you run your dishwasher a few times with no dishes in it, adding straight white vinegar to clean it out? How old is your dishwasher?
Apr 02, 2013 | Whirlpool Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishwasher is not cleaning dishes
Jul 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher just doesnt get dishes clean anymore. some food left on dishes. there is always water pooled in bottom of dishwasher, but I've cleaned it out well at the bottom
Check your vacuum breaker. Its some times mounted up on the back of your sink. If it gets stopped up it will cause your dish washer to not drain or clean properly. Good luck.
Aug 30, 2009 | Dishwashers
Dirty dishes and now a flashing light
dishes not coming out clean might be because u need to clean your dishwasher.. but with the electric shock aswell ... i think its done for .. go get a new one.
Jun 21, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Sep 14, 2006 | GE GSD2200Z Dishwasher
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
268 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
