Question about Pyle pro Pwma930i Vhf Wireless Portable PA System/echo With Ipod(r) Dock (600 Wa
I have a PWMA9301 portable PA System, and there is no sound coming out of the mic nor can I hear music from the speaker can some one help me please... I have an event coming up this Sat. and I need it bad... Thank you
Stagepas 300.Why does one of the mic volume controls, have to be at full level to hear anything through the speakers the others are OK ?
I would suspect the input jack on that channel is either bad or has a leg come loose from the circuit board.
Jun 04, 2016 | Yamaha STAGEPAS 300 PA System
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Crackling front speaker
kinda over driving it heh??
Mar 14, 2014 | Peavey PR15 400w PA Speakers
No sound from speakers how to fix the problem
Assuming that you've checked the fuse, and the lights come on...
1) Can you hear any "hiss" from the speakers at all?
2) What have you tried to input into the device? (guitars, keyboards, mics, etc.)
3) Have you reset all buttons to "basic" mode?
Let me know, and we'll go from there...
Jan 19, 2013 | Behringer Europort EPA900 Ultra compact...
Problem is after a few minutes i lose all sond comming from my speakers
Not likely a grounding problem. Run a test: Turn on unit with NO sound into the mics and wait 5 minutes... now try the mics. If they start working for a few minutes, then the amp is being overdriven. These small systems can be overheated and a thermal protector shuts them down to protect them. A hidden problem is if the mics are in front of the speakers you MIGHT have ultrasonic (above hearing range) feedback that may be overheating the unit. Put your speakers nearer the audience and mics behind. If problem persists, exercise your warranty.
Oct 21, 2012 | Harbinger HA120 Portable PA System
I have the Harbinger HA120 Portable PA System set up in my room. I've had the system for about two years, and naturally have put some loud music through the speakers. However, now, when I send anything...
You need to do some test on the equipment. First check the resistance of each speaker. You may have a bad cable... and yes you can destroy the speakers with too loud a signal... HOWEVER if the system is made to work together this is USUALLY not a problem.
Aug 25, 2011 | Harbinger HA120 Portable PA System
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
What is the best setting EQ wise for a Sure beta 58A and a Sennheiser e835 mics? I have the HA120
Always start with flat setting. Be careful of boosting highs as feedback may be a problem Put the speakers forward so mics can't "hear" them.
Apr 06, 2011 | Harbinger HA120 Portable PA System
Hook up extra speakers
Most of these portable PA systems do NOT have amplifiers capable of driving extra speakers SAFELY without risk to the amp.
I would NOT attempt to drive more speakers without using another amp to drive those speakers.
Sep 19, 2010 | Peavey 00511800 Escort Portable Sound...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Pyle pro Pwma930i Vhf Wireless Portable PA System/echo With Ipod(r) Dock (600 Wa Logo
47 people viewed this question
Top Pyle Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Pyle Music Expert? Answer questions, earn points and help others
