Question about Garden
I have a G2500VH pressure washer that has started to pulse when the trigger is squeezed. This happens if I use the 0,25, and 40 degree nozzles BUT if I use the one for low pressure(detergent use) it will hold pressure fine. I have changed the unloader valve, checked all the valves and seals ad they seem to be fine. What could be the problem?
  • Ken Aug 02, 2013
    I have changed the spill/unloader valve as mentioned in the original inquiry. I even greased with silicone grease the one end of the valve as instructed by Karcher but still the pulsing continues. I have also taken the pump apart and cleaned all the rubber seals and other valves but to no avail.
  • Ken Aug 02, 2013
    I have changed the spill/unloader valve as mentioned in the original inquiry. I even greased with silicone grease the one end of the valve as instructed by Karcher but still the pulsing continues. I have also taken the pump apart and cleaned all the rubber seals and other valves but to no avail. I have seen postings with suggested fixes for the hose and trigger, piston springs, and other internal valves. I think if i can't find a solution, I will have to purchase a new one, time is of the essence with summer quickly disappearing.
    Sergeant:
  • 429 Answers
Do you mean pressure on and off with the hp tips and smooth and steady with chemical tip?
Posted on Aug 05, 2013
  • Ken Aug 05, 2013
    That would be correct. With the low pressure tip in place the pressure washer operates just fine, no pulsing. Place one of the other nozzles (non detergent) and it will pulse.
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
Dxpw3025 motor drops rpm when triggers pulled
Look at the size of your spray nozzle, it may be too small causing excessive back pressure and thus excessive strain on your engine. Your nozzle should be a 3.0. If you are using the 25 degree nozzle for example, it should say 2503 on the side of the nozzle.
Nov 26, 2016 | Dewalt Pressure Washer - DXPW3025
Why does it build pressure, but when I squeeze the trigger the engine stays at idle?
POSSIBLE this look picture hose coupling with water stop put on the tap side or lime in valves after long time or a nozzle with dirt close beaten
clogged nozzle on the lance
Bypass not working (lyme)
if you disconnect the lance and the handle grip is giving enough water and water comes out then the nozzle clean it with a little paperclip.25944841-me02dbjx1ofpduv3i0g3gg4u-5-0.jpg
Nov 06, 2015 | Garden
Low pressure
It sounds like the nozzle is worn or the wrong size ( too big )
Oct 23, 2014 | All-Power America Steele Products SPWE175...
Why does my pressure surge
Common problem across brands. When you spray water the drop in pressure triggers the motor to take the hose pressure ~ 30 psi and boost it to ~ 3000 psi. Water coats these parts with calcium (hard water) or other junk and water contains bacteria which causes slime and scale. Once that pressure switch / valve is sufficiently clogged it doesn't move smoothly so it can fluctuate between sending a yes / no signal about whether you are squeezing the trigger or not. This causes the pulsing.
EZ test: take the the tip off the wand, start the unit, squeeze trigger - should run continously with no problem. If it does for sure you need to watch a video on dissembling and cleaning the valve body. It is not hard but you must work carefully to avoid losing parts especially springs and take digital pictures to record the order for reassembly.
Jun 04, 2014 | Dewalt DPD3100 Gas Pressure Washer
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Apr 13, 2014 | Garden
The trigger on the wand of my Karcher model K 368 M will not re-engage for several minutes after the trigger is released. If I repeatedly squeeze the trigger for a few minutes, eventually the switch will...
it sounds like a flow switch that is installed in the inlet of pump can get stuck at times if you have a soap nozzle select it usually more flow moves the flow switch try and clean the flow switch if possible.
Aug 10, 2013 | Karcher K3.68MR Electric Pressure Washer
I have a Mi T M job pro 3500psi pressure washer that may have a clog in the nozzle, how do I release the pressure in the line? All the pressure fittings are stuck (probably from the pressure in the line),...
If the engine is off, try unscrewing the hose at the pump. Put on a thick pair of gloves and start to unscrew slowly till you feel some preasure escaping. It should release quickly. You can use a piece of wire brush wire to unplug the nozzle. Wear safety glasses while performing this task, and expect it to happen again. Good Luck Friend.
Feb 07, 2018 | Mi T M WP-2700-4MHB Pressure Washer
We have a Karcher G2500VH pressure washer. If you start the engine with the trigger pulled on the spray wand it will run at full pressure until you release the trigger. after that, when you pull the...
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
Mar 07, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
