Question about HP 301xl Colour Ink For Deskjet 2050se 2054a
Hp2054a reset expired cartridge - HP 301xl Colour Ink For Deskjet 2050se 2054a
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
Jul 06, 2014 | HP DesignJet Office Equipment & Supplies
I bought HP 940 XL some months ago and my printer says the date has expired
What date has expired? Are you talking about the cartridge date? If yes then thats what HP is known best for: Making people buy cartridges all the time. Its said that most cartridges work fine even after their expiration date so you should try resetting the date on the cartridge. This explains it: http://www.ehow.com/how_7354802_reset-hp-940-chip.html
Watch this too: http://www.youtube.com/watch?v=LDH2UcMd7LI
Nov 15, 2012 | HP Hewlett Packard - 940XL Four Pack Black...
After refilling i attached the cartridge but not printing printer showing "check cartridge" i have done refilling like this 3 times without any problem but this time i am facing this problem .Kindly...
search for the specific cartridge you have and keywords such as "refill, reset expiration, contacts" for instructions on how to fool the printer into thinking the cartridge isnt expired yet. This works for most HPs:  http://www.refill4.com/refillinstructons/cartridges/hp-56-27-21-57-28-22.htm
Jul 27, 2009 | Office Equipment & Supplies
Reset HP 7110 to factory settings
usually setting your computer to a date before the expiration date of the cartridge. If your printer has a date function try this first on your printer.
Jun 27, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Won't work displays Right Cartridge incorrect. Re inserted a few times.
It seems that printer expires the cartridges after about 18 months even if it's finished or not ,you will have to buy another cartridge to reset it.
http://blog.loaz.com/timwang/index.php/2006/02/11/error_right_cartridge_incorrect_printer
A quick reset without buying a new cartridge is to use a discarded empty cartridge in the printer to reset the printer and then reinsert the cartridge you have now.
Jun 01, 2009 | HP PSC 2175 All-In-One InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Supply Expired!
Reset the printer to the factory default setting that should resolve the issue, you can provide me the make and the model so i can give you the instructions how to set the printer to default factory settings.
May 23, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Expired HP printer cartridges
I have the identical problem with an HP Business Inkjet 1100.
Once cartridges were past date, the printer would no longer print from Windows XP. It would however work perfectly from Linux.
I did not find an ini file as mentioned in other posts, and I really did not want to open the printer as it worked fine in Linux.
The following fixed the problem:
1) Click on Start button, run
2) Type in regedit, enter
3) Navigate to HKLM/software/Hewlett-Packard/HP Printers/HPWH Toolbox/Common
4) In the right panel, right click on Ink, pick modify
5) Change 0100 to 0000
6) Save and reboot
Jun 13, 2007 | HP cp1700 Color Inkjet Printer
Printer
Top Solution thanks - Take that HP!
Slight amendment as battery is hard to remove:
The battery is accessed by opening top then can be seen on extreme left at front. No need to take it out, slip a strip of plastic like an old credit card under the clip on top of battery to insulate it. Then do a soft reset (# and 6 and power down) with the battery insulated. Power up - Power down, remove insulator power up. Eureka!
Jan 24, 2007 | HP Officejet 7130 All-In-One InkJet...
HP 301xl Colour Ink For Deskjet 2050se 2054a Logo
137 people viewed this question
Seeker5211
Seeker5211
