Question about Maytag Washing Machines
I have a Maytag washing machine - mah22pda, with coin. sometimes when selecting a program, the display the minutes begin to climb, but the drum does not rotate. once the minutes of display will reset and do another washing machine works. hello john
ttech
  • 139 Answers
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
  • 1462 Answers
SOURCE: Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Posted on Oct 16, 2008
  • 3 Answers
SOURCE: coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Posted on Nov 20, 2008
matrixgent
SOURCE: LE fault code for LG WD-1019bd washer
I found that in winter time not a problem with my LG front loader, but when the temperature went over 30 Celsius the problem came back and intermittent like yours did, there was also an unusual noise coming from the machine.
What I did to fix the problem was to remove the stator and place it in the freezer for about half an hour or so, I also cleaned any minor dust and grit from both the Stator magnets and the Stator drum, replaced it still very cold and now it works well with no more unusual noise and the outside temperature has no more bearing on the machine not spinning this day!
I hope this helps!
Regard
Andre’
Posted on Dec 09, 2009
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Sounds like coins between the basket and drum. How do I remove the coins?
If it has baffles for washing, check to see if you can lightly press the baffle to one side (press firm but don't snap it out) while rotating the drum by hand. I do this with my Whirlpool Duet and the coins eventually just slide out and into the drum where I can see them.
Dec 06, 2010 | Maytag MAH8700A Front Load Washer
Can't interrupt the washing cycle on coin operated Mah21pddww
Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
By pass coin mech for a maytag washer mah21pddww
All you have to do is program the machine to run with no coins Open the service hatch and use the woolens key to scroll through to the setting which is your multiplier setting it may be set to 610 for example you need to set it to 600. While viewing this number use the permanent press keypad to change this setting each press changes it by one increment keep pressing it until it goes back around to 600 Then close your service hatch and the machine will be set to work for free you only have to select which program you want to start.
Hope this Helps
May 13, 2009 | Maytag MAT12CS Top Load Washer
Coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
Jan 25, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag commercial washing machines/dryers that use tokens. is it easy to convert these to accepting coins instead? how is this done?
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Oct 28, 2008 | Maytag Washing Machines
Water supply
look on the control board. there's some DIP switches. these are set according to the number of coins needed to run the machine. the coin acceptor reads the number of coins going through it and advances the control board one increment for each "good" coin. objectionable coins are rejected.
Sep 06, 2007 | Maytag MAT12CS Top Load Washer
Empty washing machine still unbalanced
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
