Question about Boston Acoustics Tvee Model 25 Sound Bar And Wireless Subwoofer black
Boston acoustics tvee model 25 subwoofer not working
The subwoofer has no power what so ever. Was working fine, but over the last 4-5 days had a buzzing sound and now it doesn't work at all. I've tried different cords but no joy. Any advice?
  • 6 Answers
SOURCE: Not enough IR range to use remote
Get yourself a very thin and small screwdriver. The type that comes in the eyeglass repair kits. Remove the cloth/plastic grill from the front of the sound bar. Locate the IR sensor in the center of the bar. Pry the dark red filter off the IR sensor and leave it off.
Problem solved, greatly increases range. I have read that there is a clear replacement cover you can buy but whats the point?
Posted on Jan 02, 2009
SOURCE: Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Posted on Jul 16, 2009
SOURCE: My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Posted on Feb 20, 2010
SOURCE: no sound in sound bar and subwoofer
for Jameslicon re wireless sub going on and off repeatedly. Both the soundbar and the sub have 4 wireless channels - try a different pairing of those channels. There is a sliding switch on the back of both units. I set each of mine to channel 4 and the problem went away. There is also a signal level switch with 3 levels on the back of the soundbar. If the wireless channel idea does not work, try a different setting on the level switch. Good luck.
Posted on Nov 12, 2010
SOURCE: hello, my boston acoustic TVee
mine is doing the same thing. have you found a fix for this?
Posted on Dec 26, 2010
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Tvee model 25 wont shut off light goes red and after 3 seconds flips back on
The TVee 25 will turn itself on whenever there is an input. If there is no audio input it will shut itself off or you can manually shut it off. Or, you can select an input that has nothing connected to it.
Sep 24, 2012 | Boston Acoustics TVee Model Two TV...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
Boston tvee doesn't work
check cable power and check cable connection
Jan 15, 2011 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Boston Acoustics Tvee Model 25 Sound Bar And Wireless Subwoofer black Logo
329 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
