Question about Frigidaire Dryers
Dryer has no power was working and just stopped
  • 24 Answers
You more than likely blew your thermal fuse from machine over heating. If your venting is either the plastic or foil flexible type you need to replace with a solid type of venting, because the former types cause the machine to over heat. Also make sure that you don't have a faulty door switch. But before tearing the machine apart make sure that you have proper voltage coming into the machine.
Posted on Jul 31, 2013
Kenmore dryer stopped working
check the door switch
Jul 30, 2015 | Kenmore Dryers
Dryer stop working has power going to all parts
Check the continuity of the thermal fuse, often the culprit. Also check the power relay. Sorry but I am not familiar with the Estate dryers. But the above are two common problems in a wide variety of electric dryers.
Nov 10, 2011 | Estate EED4300TQ Electric Dryer
Admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Jan 07, 2010 | Dryers
Dryer stopped working - cye4000AYW
The answer is likely yes. Look on the back of the dryer, for an open hole that seems to serve no purpose. using a flashlight, peer inside this hole, and any others like it, and look for some sort of button.
Also make sure power is disconnected before doing any of this.
Dec 16, 2009 | Magic Chef Dryers
Dryer stop working
Check the breaker for the dryer power. The breaker may have tripped or lost half of the power supply.
Sep 24, 2009 | Dryers
Dryer stopped- not fuse
are you sure you have power to unit? first check for 240volts @dryer receptacle,then you could have either power wires or the neutral wire inside dryer burned off or broken, if it has an electronic control panel there is an electronic protection fuse to protect controls from surges
Aug 24, 2009 | Dryers
Whirpool dryer stopped working
Check the following to combat this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jun 18, 2009 | Whirlpool LER4634J Electric Dryer
Yes it maybe a fuse problem .But first you want to make sure the door switch is working.
May 21, 2008 | Dryers
Kenmore elite
It should just mean "Power Failure". Restart your dryer. Does your house loose power a lot? Or just the dryer. Check your power to the dryer.
Nov 18, 2007 | Kenmore Elite HE4 Electric Dryer
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
