Question about Home
Louvre space saver assembly instructions
I am missing the instruction for my Louvre bathroom space saver. Where can I get directions?
I really thought that there would be instructions in the box..I really don't think that I should buy something than have to go out of my way to get a handy man to put it together. I am capable of doing that myself if I had the instructions. I also don't feel that I need to call someone to get the instructions...looks like it might be a problem for everyone...I don't mind looking them up on line and print them but other than that not interested...guess it will just have to go back to bed bath and beyond...
Posted on Mar 06, 2014
2 Suggested Answers
  • 1739 Answers
SOURCE: I bought a bath space
Was able to find a website for the manufacturer. They do not post their assembly instructions but they do provide a webform for requesting replacement parts. Suggest you send a request for the assembly instructions.
See here: http://www.zenith-interiors.com/Contact/Contact.htm
Posted on Mar 01, 2011
The air swing button is not working
moat air conditioners suffer this fault after time
research has shown the the small plastic gears in the actuator , break teeth
the only repair is a new louvre actuator assembly unit if they are available from the service agent
May 27, 2015 | Heating & Cooling
Can't swing
Broken louvre ( At the drive end there is a small slot or groove which can sometimes crack or break) Faulty swing / louvre motor. Damaged or faulty wiring to the motor.
Apr 19, 2015 | Heating & Cooling
I bought a newport space saver for the bathroom and it did not come with the assembly instructions. can you provide instructions
Hi...
can provide the brand and model in detail.?
try to click the link below for your reference.
http://www.vitabath.com/OwnersManuals/SignatureManual.pdf
best regards
Jul 16, 2011 | Home
Luvre will not open when A/C is on
You need to replace the louvre motor which is located on the side of the louvre. Two screws and plug in cable. Quite simple. Take it as a sample to your electrical supply shop.,
Nov 03, 2009 | Heating & Cooling
I cannot find the swing button on my remote for my LG LS-D2461HS
The swing button is usually on the right side of the remote and has three little arrows pointing toward an arc or half circle line with arrow up and down. If you press this once it will go on auto swing, you can wait for the louvre to get to the right position and then press it again to stop in that position. You can also on some models change the left/right airflow direction in the same manner or manually direct the airflow to one side. If all fails, you can gently manually position the louvre up or down.
Dec 13, 2008 | LG LSC121PMA Split System Air Conditioner
Bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Aug 08, 2007 | GE JVM3670 Microwave Oven
Home Logo
774 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
