Question about Powerhouse PH3100Ri Inverter Generator CST-69273
I have a Powerhouse 3100Ri generator. Recently while camping I turned the generator off, using the ignition key, then tried to restart. The engine did not crank on the first attempt, but did on the second and started right away. After I turned the generator off again, I could not get the ignition to crank using the ignition key. The remote start did not work either. However, I turned th key to the start position and started the generator with the hand pulley. I'm guessing it might be the ignition coil, but do not have a clue as to what it is or how to repair. Any assistance is greatly appreciated.
Possible ignition switch problem?
Ignition switch is likely worn out making intermittent contact.
Jan 28, 2016 | 2003 Buick Rendezvous
Why does my powerhouse PH3100ri generator run fine for about 5 minutes or so then dies and it will not start again in till it sets for 30 minutes or so then it will fire right up please help!!
Maybe faulty CDI ignition module ? There are a number of components ( electrolytic capacitors ) in the module that can fail with temperature rise.
A test... Remove the ignition plug lead when motor has stopped after the 5 minutes and put a wire inside the plug cap and place end near a metal part of motor. Careful not to zap yourself... Pull starter and look for ignition spark. If there is no spark then probable fault is ignition module. If there is spark then problem may be in fuel system.
Do check vent on fuel tank is open.
Do check choke is turned to off once motor is running.
Do check the oil level as the low oil cutoff can cause shutdown and will result in no spark.
Mar 16, 2015 | Powerhouse PH3100Ri Inverter Generator...
I have a PH3100Ri . It will not start with remote or with manual switch. The starter motor does not turn. Battery has full charge. Any ideas
My powerhouse PH3100 ri turns over with the remote and key but will not start , when it did run it ran for 10 mints and shut down and now it will not start at all
Jun 30, 2013 | Powerhouse 3100 Watt Inverter Generator...
How to change fuel filter on a PH3100Ri
Check to ensure you did not trip any of the amp switches. My generator acted the same way until I reset the switches.
Apr 11, 2013 | Powerhouse PH3100Ri Inverter Generator...
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
What grade of oil do you use in the Coleman powerhouse 8000 with the 18 HP twin?
For normal operating conditions use straight 30 weight. For below 30 degrees use 10w 30.Thank you
Jan 09, 2011 | Coleman Powermate Premium Plus 6250W...
Ignition is locked, recently changed battery & now can not start truck. tried reseting alarm by unhooking battery, turned steering wheel also played w/ gear shifter to no avail. 2002 avalanche
Turn on the ignition with engine OFF.
Try to start engine, then release the key to ON
Wait 10 or more minutes till SECURITY TELLTALE turns OFF.
Turn OFF the ignition, wait 5 seconds.
Repeat this procedure 3 more times, it takes 30 minutes.
You must turn the ignition key OFF before starting the engine.
To be on the safe side OFF means take the key off, and hold on your hand for 5 seconds.
If you missed something visit GM dealer, and they gladly will provide you a print out of this procedure.
Sep 05, 2010 | 2002 Chevrolet Avalanche
1992 Volvo would not start using the ignition switch
Have you check your wiring to the starter?
Mar 04, 2009 | 1992 Volvo 240
Powerhouse PH3100Ri Inverter Generator CST-69273 Logo
121 people viewed this question
Top Powerhouse Electronics - Others Experts
Are you a Powerhouse Electronics - Other Expert? Answer questions, earn points and help others
