Error 15000-00801, how do we correct this - Office Equipment & Supplies
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
08:11 error in hp designjet t1100
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
  • Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
  • Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.
  • Check that the memory module in the Formatter is installed correctly.
  • Check that the connections between the Formatter, the Formatter and the Formatter are not damaged and are correctly connected.
  • Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
  • If the System Error continues, replace the Main PCA
  • If the System Error continues, replace the Formatter
  • If the System Error continues, replace the Front Panel
Jul 27, 2011 | HP Designjet T1100ps Printer
I did a boot scan and three errors showed up error 42125, 42127, 42144. Is there anything that I can do to correct it? Thanks
Errors 42144, 42125 and 42127 showed on doing Avast scan before booting up. Please tell me ho;w to correct these errors
Feb 06, 2011 | Computers & Internet
Correct loading of ink cartridges. Error E2
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
Dec 08, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
Error correction mode
    1. On the operator panel, press Fax.
    2. Press Options until ecm or error correction mode appears.
    3. Press the right arrow (+) to choose 9600,
    4. Press Select.
    5. Make sure the it is saved...
Dec 12, 2007 | Lexmark X4270 All-In-One InkJet Printer
251 people viewed this question
k24674
