Question about Bosch B22CS30SN Side by Side Refrigerator
Bosch refrigerator water dispenser panel
The LEDs at the dispenser stopped working. I need to know how to disassemble the panel to the part if needed. I don't see any screws anywhere and I don't like to force anything inappropriately. I haven't been able to find a service manual or disassembly schematic for Bosch anywhere. Please help. Thank you in advance.
4 Suggested Answers
  • 19 Answers
SOURCE: Asterisk symbol Bosch Refrigerator B20CS50SNS
It means it is time to change the water filter. You can hold the button down for a while and it will reset whether you change the filter or not.
Posted on Jun 10, 2009
  • 47 Answers
SOURCE: on a new (2 months old) Bosch refrigerator
this is probably a burnt out water solenoid, id suggest contacting the place you purchased it from and see if you have warranty, a warranty agent will be able to fix this problem. if not you may have to call a refrigeration mechanic... a long shot would be to check that your water tap is on ( the one that feeds your fridge.. its probably behind or above your fridge.. perhaps in a cupboard next to it.
Posted on Nov 11, 2009
imufo2
  • 3773 Answers
SOURCE: I have a Bosch Refrigerator, Model # B20CS80SNS.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 18, 2011
The ice maker is not working and the water dispenser is not working right. I've changed the filter,checked the water supply and reset ice maker and waited 24 hours. What's next?
First make sure you have water going to refrigerator Samsung water filter heads go bad and won't let water thru or it could be the fill valve it's right near the filter
May 30, 2016 | Samsung RF4287HARS French Door...
Model PHSC39EESSO. Why are water and ice not lighting up or working?
Thank you for your inquiry, Rick!
I understand that the water and ice on your Frigidaire refrigerator is not lighting up or working properly. This could be a possible issue with your control panel or dispenser. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue you may need to disassemble your refrigerator and test each component to assure proper replacement of parts. I would suggest having a professional technician out to disassemble your refrigerator. Hope this information is helpful. -Matt
Jun 06, 2015 | Frigidaire Refrigerators
I have two Bosch fridges. I just bought this house and there is nothing in either fridge. Worked day we took possession of home, but both stopped working. They have power just won't cool.
Bosch is a high end manufacturer of appliances. Occasionally things can go wrong, such as fluctuations in temperature. Bosch's policy is to charge for calls to customer service advice, even when the appliance is still under warranty, so it's worth trying these troubleshooting steps before making the call. Bosch refrigerators also have an appliance self-test which you can run.
Instructions
    • 1 Check that the plug is inserted into the household power outlet at the wall. If there's no text displayed on the display panel, it is because there is no power to the fridge.
    • 2 Make sure that the door hasn't been left open if the warning signal sounds. The warning signal means the temperature is rising, and frozen food can be at risk. Visually inspect that the ventilation openings aren't covered by household objects, debris or dirt. Press the "Alarm Off" button to switch off the alarm.
  • 3 Ensure that the temperature controls are set correctly if the fridge or freezer compartments get too cold.
  • 4 Check that the water supply is on if the ice-maker isn't producing ice. Test the water supply by using the water dispenser on the door. If "IWD Off" is displayed on the panel, the ice and water are supplies are off and need to be turned on again.
  • 5 Press the "Condensation Heating" switch near the ice dispenser and water outlet on the door if condensation forms on the outside of the refrigerator. If the environment around the refrigerator is too humid, the appliance can compensate for that.
  • 6 Run the self-test program to identify major faults. Switch the refrigerator off and wait five minutes. Switch the refrigerator on again. Press the "Select" and "Options" buttons at the same time for five seconds. The self-test will commence. Keep an eye on the display. "E" indicates a fault which needs reporting to customer service. The number in the US is 1-800-944-2904.
  • http://www.ehow.com/how_5769746_troubleshoot-bosch-refrigerators.html
  • Nov 27, 2014 | Refrigerators
    The water will not dispense and the ice cubes will not come out. I noticed on the front panel that IWD is "off" and that it shows "lock"ed at the bottom of the screen. I know that the...
    Press Freezer and Super at the same time for 5 seconds to turn Ice & Water Dispenser on. This will remove "IWD Off" indicator. If it is locked, press the Alarm/Lock button for 5 seconds to unlock it.
    Feb 17, 2011 | Bosch B22CS50SNS Side by Side Refrigerator
    On a new (2 months old) Bosch refrigerator (B22CS..) the water dispenser stopped working. Anything I can do?
    Nov 11, 2009 | Bosch Refrigerators
    Water/ice dispenser sticking on
    We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
    Sep 11, 2009 | LG LRSC-26922 Side by Side Refrigerator
    GE Profile Refrigerator water dispenser stop working...
    This could be a bad water valve on the back of refrigerator or the dispenser is not asking the water valve to open. There are 2 valves in back, one is for ice maker and other is for the dispenser. I will help to try to locate the problem if you need, let me know, Thanks, Sea Breeze
    Mar 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
    I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
    Jul 28, 2008 | Bosch Washing Machines
    Bosch B22CS30SN Side by Side Refrigerator Logo
    37 people viewed this question
    Top Bosch Refrigerators Experts
    John Tripp
    John Tripp
    Colin Stickland
    Colin Stickland
    jasbo
    jasbo
    Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
