Question about Husqvarna 675 hp 21" Honda Rear Bag Push Lawn Mower with High Wheels CA Mo
Intertherm model nomenclature
The long narrow spring that controls the throttle fell off. Where does it go?
    Master:
  • 969 Answers
Look for 2 plates on top of carb. Rear plate, rear hole should be spring attachment.
Posted on May 28, 2014
Reduced engine power message
You don't say what make an model vehicle ! But with most vehicle makes it has to do with the Throttle Actuator Control (TAC) System , electronic throttle control ! are you having reduced engine power ? There are probably DTC'S - diagnostic trouble codes stored in the PCM - engine computer .
The throttle actuator control (TAC) system is used to improve emissions, fuel economy, and driveability. The TAC system eliminates the mechanical link between the accelerator pedal and the throttle plate. The TAC system eliminates the need for a cruise control module and idle air control motor. The following is a list of TAC system components:
The accelerator pedal assembly includes the following components:
The accelerator pedal position (APP) sensor 1
The APP sensor 2
The throttle body assembly includes the following components:
The throttle position (TP) sensor 1
The TP sensor 2
The throttle actuator motor
The throttle plate
The engine control module (ECM)
The ECM monitors the driver demand for acceleration with 2 APP sensors. The APP sensor 1 signal voltage range is from about 0.98-4.16 volts as the accelerator pedal is moved from the rest pedal position to the full pedal travel position. The APP sensor 2 range is from about 0.49-2.08 volts as the accelerator pedal is moved from the rest pedal position to the full pedal travel position. The ECM processes this information along with other sensor inputs to command the throttle plate to a certain position.
The throttle plate is controlled with a direct current motor called a throttle actuator control motor. The ECM can move this motor in the forward or reverse direction by controlling battery voltage and/or ground to 2 internal drivers. The throttle plate is held at a 7 percent rest position using a constant force return spring. This spring holds the throttle plate to the rest position when there is no current flowing to the actuator motor.
The ECM monitors the throttle plate angle with 2 TP sensors. The TP sensor 1 signal voltage range is from about 0.5-4.25 volts as the throttle plate is moved from 0 percent to wide open throttle (WOT). The TP sensor 2 voltage range is from about 4.45-0.7 volts as the throttle plate is moved from 0 percent to WOT.
The ECM performs diagnostics that monitor the voltage levels of both APP sensors, both TP sensors, and the throttle actuator control motor circuit. It also monitors the spring return rate of both return springs that are housed internal to the throttle body assembly. These diagnostics are performed at different times based on whether the engine is running, not running, or whether the ECM is currently in a throttle body relearn procedure.
Every ignition cycle, the ECM performs a quick throttle return spring test to make sure the throttle plate can return to the 7 percent rest position from the 0 percent position. This is to ensure that the throttle plate can be brought to the rest position in case of an actuator motor circuit failure. Observe, under cold conditions, the ECM commands the throttle plate to 7 percent with the ignition ON and the engine OFF to release any ice that may have formed on the throttle plate.
Aug 21, 2016 | Cars & Trucks
Throttle trigger spring placement enlarged view mcculloch model ms40a
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Aug 01, 2016 | McCulloch Garden
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Gas petal not working
The linkage spring must be broken or the cable to the throttle body has broken. Check for broken cable at pedal end and throttle plate.
May 03, 2014 | 1990 Volkswagen Golf
The govenator spring fell off my push mower
make sure not to stretch it out this is critical under filter houseing is the throttle useally white plastic on a shaft going down through carb and has a hole or 2 one for governer rod and the other for the spring then a tab a inch or so away with a hole carefully hook into the metal tab and carb with out over stretching the spring
Sep 05, 2012 | Mtd 22" Yard Machine Push Mower
1987 jr50 throttle cable to carbuator
On top of the carburator is a round cap where the cable passes through, un-screw it, remove the spring underneath, along with the piston/needle assembly. Thread the cable through the cap and then the spring, compress the spring by hand and pull the cable slack through. The top of the piston has 2 holes side by side, one larger than the other,with a narrow groove connecting the two together, thread the cable end into the larger hole and while holding it with one hand, use the other to slide the cable through the narrow groove connecting the 2 holes so the cable end is now under the smaller hole.
Mar 23, 2012 | Motorcycles
Hi, i pulled the carby off and a small spring fell out, cant see where it goes to replace it, any help appreciated, regards wally. victa ult60 motor
What is the brand of mower or carb? Did the spring come out of the carb itself? Some power mower linkages have springs that hold the throttle and choke springs in place. I will try to help if you can provide more info about your make and model.
Mar 05, 2011 | Garden
Husqvarna 675 hp 21" Honda Rear Bag Push Lawn Mower with High Wheels CA Mo Logo
85 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
