Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Fisher and paykel 913T soft touch dis...
By gilly3003 on Aug 31, 2007
My unit seems to be leaking in front bottom corners .
As I have purched second hand I was wondering if a lower rubber door seal should exist ANYWHERE on the lower door section or the body to stop tray and spray water leaking from the corners of the door .\
Thanks Gilly3003
Same Problem
Apr 29, 2008
-   My Kitchenaid dishwater started draining water from right lower corner onto the floor. I called and asked Kitchenaid if a food screen could be clogged. They said there is some sort of "disposal" in the dishwater that grinds up waste and wouldn't allow backup. Could the "disposal" be broken? Could it just be a door seal? H E L P!!! penwig@charter.net-   Guest
Apr 08, 2008
-   My dishwasher also leaks occassionally. Only once or twice a week. Water flows out of bottom right corner onto floor. Seems to be a lot of water all at once, then stops. (it doesn't leak throughout the entire dishwashing cycle). Have checked dishwasher while draining and it seems to drain fine. Have checked underneath dishwasher and it is not leaking there. Only out the front bottom corner. Any help would be great!-   bombermom
Dec 25, 2007
-   Dishwasher intermittently leaks at bottom left hand corner, allowing water to flow all over the floor. Seems to happen about once a week. At other times it works fine. To fix it I have drained standing water from the dishwasher and started it up again. Seems to run fine then. Could it be that a water outlet is blocked at times? Why would this not happen all the time?-   Guest
Best Solution
posted on Jul 01, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem and replaced the door seal. You need to remove the front door to do this. Requires some 'handyman' experience.
Solution #2
posted on Feb 17, 2008
Very Helpful)
shelburn
Rank: Apprentice
Rating: 100%, 2 votes
my bosch shu5306uc is coming up with f error code how do i fix it? please help?
Comments:
Feb 17, 2008
- My bosch shu5306uc has error code which is not allowing the dishwasher to fill, what could be the problem?
Was this helpful?
Yes
No
Solution #3
posted on Dec 30, 2007
Very Helpful)
chriski1
Rank: Apprentice
Rating: 95%, 11 votes
The hoses could be kinked. Also check if something is in the filter below the utensil basket. Another possibility is the dishes are loaded higher than the top of the machine and when the cover comes down before a wash cycle it is not fully closing. This will cause water on the floor as it leaks inside the cabinet.
Was this helpful?
Yes
No
Solution #4
posted on Sep 08, 2007
Helpful)
Bookers
Rank: Master
Rating: 89%, 33 votes
They do not have bottom seal, problem possibly is door cabinet seal or loose dispenser leaking, just had that problem woth one of those the other day
Was this helpful?
Yes
No
Solution #5
posted on Sep 30, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the exact problem with my dishwasher. The solution was to replace the bottom spray arm. The existing one was cracked and was jetting water at the door thus making it leak. Replacing it stopped the leaking.
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
what brand dishwasher should i buy?
Answer
What new dishwasher do you recommend. I have a family of 7 and the dishwasher is constantly in use.
Answer
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe... (More)
Answer
dish washer wont drain what do I do , whirlpool model du915 leaves water in bottom after cycle... (More)
Answer
E4 fault showing machine beeps
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
