Question about Stihl Grease Nipple Fitting 83, 85, Fcs, Fcs-km Part 9594-003-0600
Location of grease4 nipples - Stihl Grease Nipple Fitting 83, 85, Fcs, Fcs-km Part 9594-003-0600
  • Stihl Master
  • 1,807 Answers
Ive highlighted the location of the grease nipple
Posted on Jul 31, 2013
Where is the thermostat located on a 2010 cheverolet impala 3.5 V6 engine
Follow the upper radiator hose to the engine, at the engine end of the hose where it connects to a large hose nipple, remove the hose and unbolt the cover, the T-stat is under that nipple cover.
Jan 20, 2017 | 2010 Chevrolet Impala
Where are the lines located to bleed the slave cylender.
slave cylinders are bled at a nipple on the end of the slave cylinder . If the slave cylinder is inside the bell housing then there will be a bleed nipple on the outside of the housing
Dec 27, 2014 | Cars & Trucks
Which is cold water connection on the boiler
Incoming cold water usually connects to nipple marked with C, and/or the nipple that feeds into water filter (if unit has built in filter)
If unit has shut-off valve, then shut off is located on cold line.
If unit is operable, then turn on hot water and see which pipe gets hot ... and then cold is other pipe.
read your product manual.
Search your brand and model on internet to locate product manual.
Otherwise re-post question and include brand and model number so product manual can be located and information can seen first-hand.
Gene
Jul 18, 2013 | Water Heaters
Location of top autotrans modulator hose to inlet manifold 1.6 16v injected suzuki vitara 1995
16v. G16B motor, that is easy, must be 3sp A/t as 4sp has non.
the modulator is at the read of the 3sp, and has hard line forward
follow that and it goes to rubber line near the plenum nipple.
hard vacuum nipple.
1: the nipple with no hose. in the engine plenum.
the 16v goes way lean with this nipple empty. at idle.
is this a 3 speed or are you reading online advice for 3sp and yours is a 4speed, (apples and oranges, diffr)
see this page for photos.
http://www.fixkick.com/slush-pump.html
Apr 06, 2013 | 1995 Suzuki Vitara
Where are the grease fittings for 1989 Mercedes 560 sel located for ball-joints
they are pre greased, no nipples. When I replace the ball joints, i drill a hole, and put my own grease nipple in. That is the diff. between the long warranted ones, and the economy ones, a lousy grease nipple. you may need replacement
Jan 21, 2013 | Cars & Trucks
I can not find the anode on my water heater
1) Copy following link:
http://waterheatertimer.org/Replace-anode-rod.html
2) Anode might be located on hot water nipple as a combo.
Insert carriage bolt when removing nipple to avoid collapsing nipple during extraction.
Regular combo anode rods are available, or buy sausage-link combo available in 12" length to fit low headroom installations.
3) Ordinary 1-1/16" hex Anode might be located under the metal cover on steel tank.
4) If unit has power vent, the anode might be under power vent.
Workaround; Install combo anode to replace hot water nipple.
Dec 06, 2012 | Whirlpool Water Heaters
HOW TO BLEED A CLUTCH ON A RENAULD MEGAN SPORT 2007
Locate the clutch slave cylinder. It will be on the joint of the gearbox and the engine. On it wull be a bleeder nipple with a rubber dust cover on it. Remove the cover, slip a ring spanner of the correct size over the nipple and fit the bleeder hose. Fill the clutch reservoir and have an assistant depress the clutch pedal fully. Open the bleeder nipple slowly and watch for fluid and bubbles to come out. Close the bleeder nipple and let the assistant release the clutch pedal, depress the pedal again and open the nipple. Do this about four times or until no more bubbles are observed coming out of the pipe. Secure the bleeder nipple, remove the pipe and spanner and replace the dust cover. Fill the reservoir and test the clutch. If it does not work properly more work on the system is required.
Apr 04, 2011 | Renault Sport Cars & Trucks
I would like to know where is the plug for dihwasherdrain plug located ot he garbage disposal
It's not guaranteed that your particular model will have a dishwasher drain nipple, but it does, it'll be on the side, near the top of the machine. If the disposer is new you must knock out the plug inside the nipple before connecting a dishwasher. If the disposer doesn't have a nipple, you can get a piece of pipe to fit to the non-disposer side of the sink where you can connect the dishwasher drain hose.
Feb 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Where is the thermostat located?
Easiest way to find it is to floow the upper radiator hose from the radiator back to the engine and there should be a nipple connection. when you take the hose off of the connection you should be able to unbolt that nipple and below it will be the thermostat. BE CAREFUL...when putting the nipple back on a lot of these were made out of brittle material and will crack easily if torqued on to hard.
Oct 02, 2009 | 2001 Ford Focus
95 mazda b4000 slave cylinder bleeder valve location
the nipple sticks out side the bell housing on the left side just above your hydralic line for your clutch,auto zones web has a complete diagraham and steps for bleeding
Jun 17, 2008 | 1996 Mazda Pickup
Stihl Grease Nipple Fitting 83, 85, Fcs, Fcs-km Part 9594-003-0600 Logo
50 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
