Question about Chaps Hyde Park 25-In. Expandable Wheeled Upright
Nead to replace wheel on chaps lugade[ FC125992 ] POK18806 ] jbalajka@yahoo.com Where do i get new wheel?
Minimum thickness for buick lesabre front rotors
Hello there
From a kind chap on this page
http://buickforums.com/forums/threads/18395-Service-limits-for-brake-rotors
For a 2000 Buick LeSabre
FRONT BRAKE ROTORS:
Discard Thickness30.7 mm (1.209 in.)
Lateral Runout (New)0.06 mm (0.002 in.)
Minimum Thickness after Refinish31.08 mm (1.224 in.)
Rotor Diameter 15 inch Wheels (New)278.0 mm (10.9 in.)
Rotor Diameter 16 inch Wheels (New)303.0 mm (11.9 in.)
Rotor Thickness (New)32.20 mm (1.267 in.)
Thickness Variation (New)0.025 mm (0.001 in.)
Sep 15, 2014 | Buick LeSabre Cars & Trucks
How do i change the font on my GX-6750 Typewriter
The Font or letter size is depends to your printing fonts or daisy wheel. Buy a different Font size of daisy wheel or printing wheel.
Jul 07, 2014 | Brother GX-6750 Typewriter
Slam man manual
Nead a slam man manual could you find one for me my e mail davidrooney1@yahoo.com
Dec 18, 2013 | Washing Machines
NEAD A NEW ENGINE
need to bring car to head shop to have them work and re done car don't need new engine
Aug 08, 2012 | 1998 Chevrolet Monte Carlo
Are Tecomec Chaps any good?
Jose, I have tried the brand a year ago. No problems! The web site you posted has the chaps I used. This one is great for blackberry picking and turkey hunting
Tecomec Wrap Around Chap
May 25, 2012 | Desa International Garden
I nead the manual for the air ride for 1986 1400 cavalcade lx
Get the workshop manual and owners manual on CD, available from www.cademaster.com while there. look for any spares you might need.
You may also want to join the worldwide Yahoo email group with over 1400 members via www.suzukicavalcade.com
Apr 26, 2011 | 1986 Suzuki GV 1400 Cavalcade LX
My Whirlpool works in every way but will not spin.
sounds like a bad door switch,to replace the door switch you will nead to remove the body.first you nead to remove the two screws behind the control panal one on each side.next pull the panal forward and flip it up.next you nead to unhook the door switch.next you nead to remove the two s-clips one on each side.next you nead to pull the body forward and remove the body.now you con remove the two screws that holds the door switch on under the door next remove the door switch connecter from the body and install the new one.next reasemble unit
Dec 18, 2009 | Whirlpool LSB6200KQ Top Load Washer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
My diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
Feb 22, 2009 | Diesel DZ7044 Watch
Chaps Hyde Park 25-In. Expandable Wheeled Upright Logo
115 people viewed this question
Top Chaps Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you a Chaps Luggage and Travel Expert? Answer questions, earn points and help others
