Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
Where do you check hyd fluid farmall 656 - Farmall IH Tractor 460, 560, 660, 2606 ITIH25
1952 Fordson major diesel hyd fluid gets into front tranny
Sounds as if the input shaft seal for the hydraulic pump that is driven off the transmission is bad and allowing the fluid to enter the transmission housing. When the fluid gets too full it aerates and causes the "root beer float" fluid.
Mar 05, 2015 | Cars & Trucks
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
Remote valves not working.you can raise frontend loader but it want come down. also the bucket want work . change all hyd fittings.and check pump pressure thats good. need help.
Change the filter. If you can lower the loader by loosening a line at the valve, suspect the valve. All lines usually dump to tank at the valve. Make sure that line is ok. If any valves are electric, suspect them even more.
Nov 25, 2013 | Farmall IH Tractor 706, 756, 806, 856,...
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
1959 farmall 560 with weak hydraulice pressure?
check the level of fluid and check the filter this may be the problem
Jul 01, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
Farmall 560 hydrolics wont work on the bucket
i am not sure but check the levers and the inside of the lever control movements.
Apr 28, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
Where is the rear end fill and level holes on a Farmall 400 Diesel?
Just check you hydraulic and transmission fluid levels,the rear end is lubed with hydraulic oil that is supplied by one or the others oil reservoir.
Mar 21, 2010 | Diesel Farmall Tractor 400,450 Gas & ...
I have a farmall M. that i can hardly turn this winter. it was ezy to turn this summer. is there a steering gear box that might be low on oil?
It could be that the grease stiffens in winter.
Speak to the supplier, it might be a common problem and therefore a simple answer ( e.g. replace the grease with a lighter type).
Dec 18, 2009 | Farmall IH Tractor 706, 756, 806, 856,...
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Checking fluids
look for a tank reservoir with a dipstick. Locate the pump or cylinder and follow the line back to the tank.
Dec 22, 2008 | Ertl International Harvester Farmall Super...
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
54 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
