Question about Western Digital (WD6400BEVT) 640 GB SATA Hard Drive
When i power up my laptop this message appear: S.M.A.R.T. Status Bad, Backup and Replace. Press F1 to Resume" After i press F1 windows starts but then my desktop freez. Can i do something to repair this HDD or i need to replace it? My HDD is WD 6400BEVT Scorpio Blue. Thx
SMART stands for 'Self-Monitoring, Analysis and Reporting Technology' and a bad status means that your drive has errors and is likely to fail soon. There is generally very little if anything you can do to repair such drives.
I recommend backing up any important data on the drive as soon as you can and replacing the drive.
Most computer repair shops will be able to retrieve data from a failing drive and supply and fit a new one for you, charges for these parts/services will vary depending on where you go.
Posted on Jul 31, 2013
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Posted on Sep 20, 2012
Slave hard disk error
drive maybe bad check pin sewt on drive to make sure they are set right.and check cables as well.
Oct 26, 2013 | Computers & Internet
Primary hard disk failure press f1
Replace the hdd and reinstall windows.
May 22, 2017 | Computers & Internet
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
TUEN ON LAPTOP AND ENDS ON SCREEN SAYING HARDRIVE BAD
> hard-drive bad
If you get a message "press F1 to continue", then do so.
Be ready to "backup" all your files and music from the disk-drive onto a USB memory-stick, or to burn some CD/DVD disks.
Then, replace the disk-drive, and reinstall Windows.
Sep 28, 2010 | Computers & Internet
When I am trying to boot up my Laptop ''Packard Bell Easynote'' I get the following message: Resource Conflict - Allocation error static node #0B Warning: Cannot Unlock Primary HDD Press Enter to resume....
you can fix that problem with your own. press f2 and then correct the time and date, then press f10. I f you got same problem again change the cmos battery then do it again.
Feb 15, 2010 | Computers & Internet
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
May 17, 2009 | Toshiba Satellite 1805-S204 Notebook
Press F1 to resume
Try changing the CMOS battery (leave the battery out for 5mins then replace with new 1) if that does not work flash the BIOS
Let me know how you get on...
Matt
Dec 08, 2008 | MSI K9VGM-V Motherboard
Repair
i think this is a os problem or hardisk problem change check hard disk
Oct 23, 2007 | Acer Aspire 5100 Notebook
Western Digital (WD6400BEVT) 640 GB SATA Hard Drive Logo
81 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
