Question about Craftsman Garden
Lawn mower will not start when hot.
Runs fine, starts when cold fine, but stop it and while hot it will not start.
    Problem Solver:
  • 14 Answers
Your mower may just be over heated. This is commron, make sure there is no dabris around the cyl inder head fins if leaves or grass get in there it will not be able to cool properly. your mower may have an air vaine on it that comes from the carb and directs air to these fins. it governs the machine if any of these parts are bent or not working properly this to will cause the mower to over heat and not start back up. Finally you may want to go and by a spark plug that is for high heat and will remove heat better than a cooler plug . good luck
Posted on Feb 09, 2014
3 Suggested Answers
  • 125 Answers
SOURCE: will not stay started Runs for about 1 minute
fuel issue. probably has junk in the carb bowl that gets sucked up when the machine start. You might be able to get away with just taking the bowl off and dumping it out (you will see it there is junk in there. then dump out the gas thats in it and put fresh gas in. Ideally you should clean up your carb which is not that difficult. an air compressor on very low pressure will provide some assistance (10-20 PSI)
Posted on Aug 23, 2009
  • 74 Answers
SOURCE: lawn mower runs well from cold but if stopped won't start
Sounds like it's running rich. If the mixture is slightly rich it will start well when cold, but when hot it floods. Check the air cleaner to be sure it's not clogged/blocked. Get a new plug for it and if this happens again just install the new plug - the new plug won't be fouled with fuel. If it started with the new plug then you're on your way to a carb adjustment (that is if the air filter/cleaner is clean)
Posted on Aug 29, 2009
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
My Briggs & Stratton Quantum 65 starts perfectly from cold but refuses to re-start when hot. Any ideas?
Do a compression check when cold, then again when hot. Sounds like when its hot your losing compression. If this is the case, it won't want to start when hot. Compression should be above 60 lbs. Thats where i would start. I hope this is of some help to you.
May 29, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
My mower starts and runs until the engine get hot.
the only way to test i think is with a known good coil or resistance check. also possible you need to check valve clearances
Apr 25, 2017 | Toro Lawn Mower With Toro Power Tools
Lawnmower with 5 hp briggs ad straton engine.starts fine when cold and runs well but if you shut it off ,it won't restart when its hot
It sounds like the choke is comming on or you are prinming it again? Dont prime a warm engine
Nov 16, 2009 | Garden
Lawn mower runs well from cold but if stopped won't start
Aug 29, 2009 | Garden
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
LAWN BOY MOWER WILL NOT START WHEN HOT. WHY? STARTS FINE WHEN FIRST STARTED.
Hello PANDJ4952, Check your oil level first. If low or a dark color it needs changing. I suggest you change spark plug and air filter too. With the engine cold clean the fins around the spark plug location of caked up mud or clogs of grass including under the mower where the blade rotates. Please let me know of the results.
Oct 25, 2008 | Garden
Garden Logo
47 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
