Question about KitchenAid Kitchen Ranges
Kitchen aid model KEDT105V display reads F5 - KitchenAid Kitchen Ranges
SOURCE: hey,
I had this problem once and I just reached through the vent on the front with a knife and turned the locking mechanism. I eventually had to have the range repaired for self-cleaning mode, but this should at least let you get the door open!
Posted on Jul 12, 2008
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
  • 104 Answers
SOURCE: My Kitchen Aid Supuerba top
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Posted on Oct 04, 2008
mgprice
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
My kitchen aid gas range display F5:E3 and contact touch board has no function
Hi
Error code F5-E3 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F5 display not turning burners on
Hi
Thanks for using FixYa. Error F5 means that the control board has failed and to resolve this unfortunately you’ll have to replace the control board. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
Hey,
Jul 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
Digital clock display on our Whirlpool cook stove model # 465 keeps reading E1 E0 -F5-
We contacted whirlpool directly and they told us what to do, their service is free.
Jul 03, 2008 | Whirlpool Kitchen Ranges
Whirlpool Electric range model RF386
cant nfind euf5 code can find eo f5 its a door loc code saing the door and latch switches do not agree try pushing stop/cancel and try again also does the oven light go off and on when you open and close the door
Dec 31, 2007 | Whirlpool RF364 Electric Kitchen Range
Open Questions:
Kitchen Ranges Logo
41 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
