How much defy amine 4 do i put in a 30 gallon tank to spray a 5 acre pasture for grazing horses
  • Brenda Roof Aug 02, 2013
    i have 5 acres to spay for weeds and a30 gallon sprayer how much in cups or oz. do i put in a 30 gal. tank with water
  • 1388 Answers
SOURCE: Air Compressor shuts off
Most compressors have a check valve installed in the tank that allows air from the compressor to enter the tank and not allow back pressure to the compressor. Also there is an unloader valve at the pressure switch that activates when the pressure switch cuts out releasing the pressure in the line. These two devices allow the compressor to start in an unloaded condition so that the motor will not strain. When you place you finger on the intake, the compressor is no longer pumping air thus there is not load on the motor. Your problem may be the intank check valve or the capacitor may be weak or bad. Simple check for both. Many volt meters have capacitor check and amp draw. The capacitor should not be more than 10 percent or rating. enjoy
Posted on Nov 28, 2008
boysor2933
  • 293 Answers
SOURCE: Only fills 80 gallon tank 1/5 or less then shuts off.
I am not familiar with your unit but if it is controlled by a pressure switch, you may try readjusting it or replace it. Weak springs of the contacts may be causing your problem. If it is controlled by level probes, then the relays of the control circuit may be defective.
Posted on Jun 11, 2009
SOURCE: almost ran out of gas. put 5 gallons in tank.
worst thing for fuel pumps is to run dry. The pressure will need to be confirmed. If none ,you overheated the pump and it will need to be replaces.
Posted on Dec 10, 2009
  • 6 Answers
SOURCE: i have a 2004 Ford F250 diesel w/170k miles.
file pump
Posted on Dec 11, 2009
brennan0331
  • 12 Answers
SOURCE: My 5 hp Campbell Iron Horse 20 gallon air
Is your release pin closed?
Posted on Dec 29, 2009
How many gallons of water in a fish tank 8 feet long by 2 1/2 wide by 4 foot high
I think you will be looking at about 500 gallons.
598.4 US gallon.
498.3 UK Imperial gallon.
Jan 31, 2018 | In Office Equipment & Supplies
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
Quantity of Roundup weed killer to spray 140 acreas of crop land
This 2.0% glyphosate is ready to apply at a rate of 3-10 gallons per acre That's 420-1400 gallons per 140 acres. Some weeds need a higher concentration than 2%. Most farmers buy 41% glyphosate concentrate, determine the number gallons of spray mixture their equipment will deliver, determine the concentration of glyphosate they need and mix the concentrate with water accordingly.
Apr 01, 2010 | Roundup "" Weed & Grass Killer
Problem fueling 1999 Dodge Intrepid
does your car run fine on the 5 gallons you stick in each time? if so I would say that your fuel pump is ok. I would take the tank out and see if there is some obstruction in the fill tube and tank orface, also look inside the tank for any floating debris, check and or replace the tank vent
Apr 07, 2009 | 1999 Dodge Intrepid
Nov 28, 2008 | Craftsman Air Tools & Compressors
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
