Question about Facebook Social Network
Currently johan nieuwoudt is shown but ansu nieuwoudt is also set up how dowe switch to ansu profile
Stsrter switch is sticking on my gold wing
Hi Clay:
Some possibles:
- switch contacts fused causing continual current.
- Solenoid contacts fused causing continual current.
MAKING ME WORRIED:
- Starters anre not intended to run continuously until the battery is dead.
- ???????????? Did the engine start but the starter continue turning?
- I'd be disconnecting the battery and charging it, then disconnecting the starter and checking EVERYTHING on that circuit to avoid cooking components.
Jul 28, 2015 | Motorcycles
How do I change my profile picture on soundcloud.com
  1. You need to validate your email first.
  2. Go to your profile form the top right corner of the website as shown below.
25468208-s0gneu0g2fgal11eylig0nxg-3-0.png 3. Hover over your current profile picture and click on upload a new image.
Feb 23, 2015 | soundcloud.com
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
Mar 18, 2013 | Hardware & Accessories
In what menu can i find the phone profile settings of my samsung corby 2 gt-s3850?
Hello and Welcome to FixYa!
Go to main menu > Settings > phone profiles.
There you will be shown all the profiles, you can set or/and edit those profiles from there.
I hope you will have a clear picture now.
Concerned, Nooh.
Jun 19, 2011 | Cell Phones
Im using gt 15503 samsung,, and it was bought in dhubai by my brother in law.. im living in philippines. using SMART network provider.. i went to their service center . and doesnt even know to set it...
  • [1] From the Main Menu select Messaging
    [2] Select Settings
    [3] Select Multimedia Messaging
    [4] Select MMS profiles
    [5] Select Profile Settings
    [6] Select New Profile
    [7]Set Profile name to Picture Messaging
    [8]Get Sert URL/Proxy and version info from your provider and set them here. i.e for T-Mobile: URL http://216.155.174.84/servlets/mms, Proxy Enabled version 1.2
    [9] Set GPRS Seetings
    [10]Get IP address/port/login info from your provider
    [11] Select Save twice
    [12] Select Current Profile
    [13] Select Picture Messaing to set as default
    [14]Power cycle phone (Turn it off then back on) and test Picture Messaing
  • Mar 13, 2011 | Computers & Internet
    How to deactivate offlinemode of my nokia e52
    To switch OFFLINE mode on/off:
    1. Press Menu (left soft key)
    2. Highlight Ctrl. panel and Open (Navigation key)
    3. Highlight Profiles and Open (Navigation key)
    4. Select a Profile of your choice and then press in Navigation key
    Alternatively,
    1. Press the on/off button quickly and the list of Profiles will be shown
    2. Select a Profile of your choice (Navigation key)
    Hope this helps. If so, kindly vote.
    -regards,
    Mrigs
    Mar 04, 2011 | Nokia E52 Smartphone
    I want loop mobile wap setting(manual) on GT I5801
    *WAP Settings For Samsung:
    WAP Settings
    1. Open Menu>Fun box>WWW Services>Proxy Settings.
    2. Scroll to the desired profile and then press Select.
    3. Fill your parameters as shown below:
    Proxy name:Loopwap
    Home URL:http://atcafe.loopmobile.in
    Bearer:GPRS/GSM
    4. Select GPRS setting>Gateway.
    5. Fill your parameters as shown below:
    IP address:010.000.000.010
    IP Port:9401
    6. Return to GPRS setting.
    7. Fill your parameters as shown below:
    APN:mizone
    Login ID:Mobile No.
    Password:mmsc
    8. Return to WWW Services and then select Current Proxy.
    9. Highlight Loopwap and press Select.
    10. To start WAP session select Home.
    11. To finish WAP session press NO.
    Feb 03, 2011 | Computers & Internet
    Outlook 2007 - will not allow me to to show contacrts folder as an email address book
    I had this very same problem. I use Windows Home Server with an Axigen mail server, but not sure if that is the problem or not that I was having, as I at one point had my profile setup to use their Outlook connector program. I am currently using POP/SMTP to get my mail from the server.
    I needed to create a new profile in Outlook for my Contacts to be shown as the Outlook Address Book.
    To create a new profile you will need your e-mail settings, like incoming (POP) and outgoing (SMTP) mail server addresses, like mail.comcast.net. You will also need your username and password for the e-mail account(s) you want to get mail from. Most of this can be accessed from your current profile.
    Beings you didn't specify, I'm going to have to assume you are on Vista/Windows 7, if you're on XP, the steps for getting to Mail are similar.
    Close Outlook.
    Open Control Panel - Start, Control Panel
    Click on User Accounts and Family Safety
    Click on Mail (32-bit)
    Click on Show Profiles...
    If there is currently only one profile, select it and click Properties, then E-mail Accounts...
    Select the e-mail account shown and click Change...
    Here is where you can get the user and server information for your e-mail account. Write it all down. You can generally get this information at your e-mail providers website as well.
    Click Cancel after you have all the info.
    Click on the Data Files tab and write down the location of your Personal Folders (PST) file. You can also select it and click Settings and then copy the locaction of the PST file under Filename: and paste it into a Notepad or just right it down. Click Cancel.
    Click Close and Close again. You should now be back at Mail window on the General tab.
    Click Add and give the profile a name different than the old one.
    Put in your Name and E-mail Address and your password twice. If your service provider is set up correctly, this is pretty much all you'll have to do and it will tell you that if found your e-mail account. If not you will have to set it up manually using the information you wrote down from the old profile.
    Manual settings:
    Click Back if it didn't find your account.
    Check the Manually configure server settings check box (lower left corner) and click Next
    Select mail type, most likely Internet E-mail, click Next
    Enter the information you wrote down from the old profile and click Test Account Settings...
    Beyond this it's a matter of getting the settings for your mail provider correct, you may need to speak with them or visit their website.
    Once you get a good test result and your e-mail account is working, click Next and then Finish
    This will take you back to the Mail window on the General tab.
    Now select your new profile and click Properties and click Data Files...
    The creation of the new profile also created a new Personal Folder (PST) file. You want to add/connect your old one to the new profile, so click Add...
    Select Office Outlook Personal Folders file (.pst) and click OK
    Now either select your old PST, if it is in this location, which it probably will be or browse to the location you wrote down earlier. Once you find it, select it and click OK
    At this point you can name it something meaningful, like your name, something to distinguish it from the current PST that is attached to your new profile, click OK
    Now select the PST you just added and click Set as Default. Click OK to the warning box that pops up.
    You will want to remove the other PST, but will not be able to until you have started Outlook and then close out again.
    You should now be able to add the Contacts as an Outlook Address Book.
    Jan 09, 2011 | Microsoft Office Professional 2007 Full...
    Sound off for K750i
    Hello Atanumitra,
    Go to setting menu/Profile setting and under Silent Profile turn off any shown ringtone whatever it is message tone,ringtone,warning tone etc.
    Regards,
    Sandeep Singh.
    Nov 21, 2007 | Sony Ericsson K750i Cellular Phone
    Facebook Social Network Logo
    22 people viewed this question
    Top Facebook Computers & Internet Experts
    David Payne
    David Payne
    Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
