Question about Westinghouse 78017 52" Comet Ceiling Fan
How to wire 52" comet #72384 ceiling fan using a dimmer switch
5 Suggested Answers
miguel1017
SOURCE: trying to replace 3 speed
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Posted on Apr 17, 2009
SOURCE: trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
Posted on Feb 21, 2010
shane_barnha
  • 136 Answers
SOURCE: i installed a dimmer for
First thing I would do is check the connections inside the Unit the ones you made while installing make sure that all connections are tight and well insulated if this was not the problem return the unit for a new one hopefully it is just a faulty unit as this can sometimes happen.
Thumbs up if helpful feedback is appreciated!!!
Good Luck!!!
Posted on Jun 16, 2011
  • 5245 Answers
SOURCE: I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
Posted on Sep 12, 2012
How do i wire the fan in a 52 inch ceiling . i have wired the light but no fan
Depending on what the fan has as options and what wires are in the circuit it will be wired differently. If you want the fan and light to work at the same time connect the fan wire to the black light wire.
Jul 03, 2014 | Electrical Supplies
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
I installed a fan and it works good but the light
Is it a standard incandescent bulb or is it a compact fluorescent light? If it has a remote with a dimmer you shouldn't use a compact fluorescent bulb as they are not dimmable. CFLs may be damaged or damage a dimmer if they are used together.
Feb 27, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan is controlled by dimmer
Yes, if the hot wire going up to the fan is coming off the dimmer, it is reduced voltage and will slow down. There maybe a separate hot from another switch??
Jul 26, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Westinghouse 78017 52" Comet Ceiling Fan Logo
19 people viewed this question
Top Westinghouse Dryers Experts
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
