Question about Car Audio & Video
I have a power acoustik PTID-6500, i want use it in aux mode, but it has IR (jack) and IPod connector (8 pin DIN), i need to know if i can use IR connector for aux and how to use it because i tried and it doesnt work, or if i have to buy the cable for ipod (8 PIN DIN to Jack)??
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
mixmaster
  • 626 Answers
SOURCE: got an aux cord to plug my ipod in, doesnt switch to "aux in" mode
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
The owners manual is here if you need it;
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_338818745,00.html
Best of Luck.
Posted on Nov 18, 2007
  • 328 Answers
SOURCE: ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Posted on Dec 31, 2008
  • 7 Answers
SOURCE: can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Posted on Jun 05, 2009
  • 227 Answers
SOURCE: aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Posted on Aug 05, 2009
Ptid 8970 it says something flips down to load dvd but for the life of me i cant figure it out
probaly the whole face folds down check all around the edges for a release if not send me a pic
Feb 19, 2015 | Power Acoustik PTID-8970NRB 7 Single DIN...
Parking brake switch wire on a power acoustik double din
this use to be simple for most units and yes it would work, however, manufactures became wise to this idea and placed a relay inside the unit that must be reset to prevent us WISEGUYS from doing so, but i do not know if this is the case with yours, if it is then you can run a toggle switch between the unit and the ground in order to reset this relay as needed with a flip of the switch
Feb 21, 2013 | Power Acoustik PTID-6250 6.2" DOUBLE-DIN...
How to get copy of owners manual? what and were is the aux port ?can I conect an ipod ? re- beosound 2000 thank you in advance rick
  • Hi, i can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 18, 2011 | Bang and Olufsen Beosound 2000 Shelf...
How do I download pictures to my Power Acoustik PTID7002NR?
You can use a USB Flash drive or SD/MMC Card or an iPod to view files (Pictures,Videos,Music files..etc) in the player.Touch the icons [USB], [SD CARD], [IPOD] according to which device you are using.The corresponding modes are switched automatically by the player when it detects one of the above devices.The player will switch to [RADIO] mode automatically when the above devices are disconnected and if there is no Disc in the player or to the [DVD] mode if there is a Disc inserted.You can view the detailed description in the following link ( http://www.poweracoustik.com/pa2006/manual%20and%20catalog/source/PTID-7002NR.pdf ).Your valuable feedback would be appreciated.Good Luck.
Jun 04, 2011 | Power Acoustik PTID7002NR Car DVD Player
I was wondering how do I play music through my iPhone with this cd player. I have a direct cable but I'm not sure what to press to make it play through my cd player. Thank you.
Once you plug in your iphone and set it to play your song(s). Set your car player for AUX this will then pick up the device playing into the direct port. Hope this helps Fix ya up.
May 12, 2011 | Power Acoustik PTID7002NR Car DVD Player
How do i set my ipod to my power acoustik ptid 5300 when i plug it in it just says close
If you bought the correct cable it should work automatically. There are no settings. However, my 5300 was flakey right out of the box and I had to send it in for repair. It works perfectly now.
Jun 06, 2009 | Power Acoustik PTID-4003TV Car Video...
Re Slingbox
The sling box has no input of 8 pin DIN,i look for another one.
I found an adapter has a female input of 8 pin DIN and has the output of female RCA jack> the only thing you do is to buy a male RCA jack in order to connect your DVD player,;
click below to see the sample picture;
511359689.jpg Pixel Perfect P.I.E. PIO/P-RCA Adapter P-Bus MCD To Aux Input
If i have helped, please click fixya;feel free to ask question,
Good luck and thank you in advance;
Jul 19, 2008 | Audio Players & Recorders
Ipod cable
you can get it at best buy. ill do some lookin' cause i have a pioneer head unit and i just built that cable. i might be able to do the same for you.
Dec 21, 2007 | Power Acoustik PTID-4003TV Car Video...
Aux
if it has aux its probably going to be right on the front, its most likely mini-din, the same connector used for headphones and pc speakers, youll need a mini-din to mini-din cable, also known as an audio cable, you can get the mcheap at radio shack usualy, its a cable that allows a pc subwoofer to be hooked up to the pc's audio card, with this just turn you ipod on and control it as normal while the deck is set to aux and you should hear your ipod. some decks have actual ipod connectors that work differntly but I personaly don't know much about them, I have the mini-din connector, and an ipod shuffle
Apr 23, 2007 | Pioneer KEH-P5950 Cassette Player
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
