Question about Maytag MZD2766GES Side by Side Refrigerator
NO WATER TO THE ICAMAKER OR THE WATER DESPENCER
  • 25 Answers
U need to check firs if u have water on the water line Che the faucet on the back on u fridge . If u have water check the water valves on the fridge, disconnect the power . Using a multimeter check the winds on the valves for continuity if u have continuity are ok. . Other way to check the valves is using a jump cable between the winds V means valve anthe wind L ( line) in the Ice maker if u jump lines u will see water filling ice maker, if u don't see water u have bad water valves.
Posted on Jul 31, 2013
When washing machine does not take fabric softener in still left in draw at end of wash
Hi,if you start the cycle again open draw despencer you should hear and see water wooshing inside if nothing then the valve that lets the water through must have packed up or despencer is blocked if you can hear the water clean despencer draw.
hope this was some help
Mar 28, 2015 | Washing Machines
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Water dispenser does not dispense water
replace water despencer it went bad.
Feb 22, 2011 | GE Refrigerators
The ice in the tray melts and runs out the despencer outlet.\r\nMakes ice but the front part of the ice tray slowly melts and water runs out the despencer outlet. Have had service man work on it four...
Your freezer temperature is not coldenough, inspect for hardness of frozen foods. Make sure that the temperature is 5 degrees Fahrenheit or lower. Carefully feel the side of the ice maker if itis warm the unit is stuck in heat for release mode. Check and replace control module.Call repairman to check this.
Thanks
Feb 05, 2011 | Electrolux Refrigerators
Drinks depencer not working
check the dispenser lever switch
May 02, 2009 | Refrigerators
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Water dispenser problem
Get a step ladder and push panel up at top to expose the compressor and wiring. Between the left and right there is nothing other than wire harness leading into the fridge. In this empty area toward the middle left is the watervalve easy to see. Unhook connections to watervalve and test for voltage to do this get a voltmeter put on AC setting put probes in each side of connection. Have some one push the despencer switch in and see if you get 120V if you do the watervalve is bad and needs replaced. If you don't get 120V than you have a short in the wire harness or the despencer control board has failed. Hope I helped.
Jan 19, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Maytag MZD2766GES Side by Side Refrigerator Logo
48 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
