Question about Zephyr Typhoon AK2100 Kitchen Hood
Control board how much does it cost for switch board (only switches), where I can buy it.
Freezer lights not working tried bulbs in fridge area and they work so its not the bulbs
Then it's the freezer door switch that controls the light. Although, modern fridges have electronic control boards designed to make your life miserable. Instead of a simple switch with a wire to a light bulb, you may have an entire computer board controlling it. The boards are _always_ expensive as heck. You can try applianceparts.com for replacement parts for your specific model.
(It was the words "Professional Series" that gave me "pause" regarding the electronic wallet cleansing you may have to deal with. I'm sorry, but I'm an old appliance tech that has lived long enough to see these appliances become unnecessarily too expensive to repair a problem that would otherwise have been an incredibly simple and cheap to repair... and frequently not even need a new part. Technology does no favors for owners regarding appliances. It is a cheap way out for the manufacturers because electronic circuit boards made in China are cheaper than the electro-mechnaical devices they replaced, yet cost many hundreds of dollars to buy a replacement circuit board; which is quite literally a scam designed to make you buy a new appliance).
Apr 06, 2016 | Viking Professional Series VCBB36 Bottom...
My lower oven element will not turn off unless I turn the cooker off from the mains.
contact someone that repairs them and ask them,look on ebay for one of the boards and you will find an ad for repair,they sell their services on ebay,this is an example,but,you might find your board or repair here, 0 results found for stove main board repair
Jul 16, 2015 | Ovens Ovens
Hotpoint aquarius wt540
Have you checked the door lock switch? If that fails, the control board will light up but wont let you start the machine as it thinks the door is still open.
Nov 08, 2013 | Washing Machines
74008072 Range Control Board
try a used appliance dealer, he will more than likely have many of those pcb boards that are junk that you can probably take for little or no money and harvest the switch from there. i have never found loose components like that for sale.
Sep 26, 2013 | Maytag 74008072 Range Control Board Part
Not switching on
I just had same issue with mine. Sears repair came over and said it was master control switch. Parts & labor almost $400 so decided not to do it and either try and replace it myself or purchase a new unit. Control board W10285180 costs about $150.
Dec 28, 2012 | Dishwashers
My Whirlpool WBM35LW refrigerator now beeps intermitantly even when the door is closed. This is very annoying.
Throw it out and don't buy Whirlpool again. I had the same fridge and it was doing the same thing and would of cost heaps to fix it.
Feb 02, 2010 | Refrigerators
The electronic touch control has fallen inside the hood this is the second time it has happened is there a plastic mounting bracket on the switch that has broken? left side of switch I can see a mounting...
Yep! This is a classic problem with the Therador PHE series hoods. Very weak design and NO help from the factory! Just the plastic housing is $82.00 bucks online. The panel is REALLY hard to access and the control boards, inside, fail regularly. The board alone costs over $200.00 bucks! These will fail to switch on the fan or change fan speeds or turn lights on and off or fan off. All of this randomly and arbitrarily so people tend to push the switch buttons too hard, causing the bracket to fail and entire panel body falling off inside. We have had ours propped up inside with two chop sticks for several years now and to get the fan to switch on or change speeds we fiddle with the chop sticks while repeatedly pushing the buttons and sooner or later it comes on. The lights rarely will come on, however. This unit is made by Bosch and they have all the same problems with NO fix except to replace ENTIRE control panel at a cost of $350.00 retail. This is truely an example of modern, fancy kitchen appliance over-engineered ripoff junk. Looks great but it makes sure that the fool who buys into the Brand name and cool design gets to pay and pay again for their naivete'.
Oct 16, 2009 | Thermador 30", 36", 42", 48", 60" Wall...
Wash machine won't spin.
If you want you can jump the switch out by taking the wires off the switch and put electrical tape around them together really tight and see if that works if so its your switch thats bad
Aug 24, 2009 | Frigidaire GLTF2940F Front Load Washer
E 3 code on smegf614ss dishwasher
A dishwasher that can not heat water means that the heating element has probably failed. Replacing that should do the trick. I do not have a source or cost of the part for you.
Apr 04, 2009 | Smeg DWI614 Built-in Dishwasher
LG plasma tv
Most likely it's the PDP panel failure. It may cost you more to repair then to buy a new one.
Jan 18, 2008 | LG 42PX4DR 42 in. Plasma TV
Zephyr Typhoon AK2100 Kitchen Hood Logo
81 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
