Question about Electrical Supplies
Where is the circuit breaker for my dutchman popup camper model 801? I blew the circuits when I plugged two heater in at one time.
  • 2712 Answers
SOURCE: Circuit Installation
The process contain a certain degree of risk, but if you follow all safety steps, you should be just fine. Most standard electric panels have a main disconnect switch or breaker at the top of the panel or load center. It is a code requirement. If the load center doesn't have one, then look for the main disconnect at a different location possibly near the electric meter. Turn it off. You better have a flashlight handy or a caving or miner's helmet, because you are going to need a light source. Circuit breakers plug into the load center. The electricity flows into each breaker via a large metal strip inside the panel or load center. It is called a bus bar. This strip is HIGHLY dangerous. Touch this strip while it is energized and you will very likely die. If a screwdriver you are holding slips and touches it, expect nearly the same result. Keep in mind that even though the main breaker may be off, the bus bar may be energized for any number of reasons! Also, the wires leading into the top of the main disconnect are always energized and represent a life safety hazard. In other words, the inside of an electric panel or load center is ALWAYS a dangerous place to be. The black wire to a circuit attaches to one end of a standard or AFCI breaker. The location is almost always a hole that is drilled through a threaded cylinder. A screw twists into this cylinder and tightly clamps down the wire. When installing a new breaker, I always find it easier to attach the circuit wire to the breaker before I plug the breaker into the panel. When removing a breaker, I usually unplug the breaker from the bus bar and then remove the circuit wire from the end of the breaker. Make sure the breaker is in the off position. The end of the breaker where the circuit wire attaches almost always has a small notch in it. This notch fits under or slides into a metal tab strip that runs parallel with the bus bar. This is what stabilizes the breaker. Without this secondary attachment, the breakers would flap in the panel much like a sail that is not tied down to the mast or the side of a boat. Tip the end of the breaker so the notch slides into the metal tab. You then align the breaker with the bus bar and push it down onto the bar. The tension tabs on the breaker open slightly and grip the bus bar as the breaker seats itself. If you feel the breaker seated itself correctly, simply turn it on. All should be well. Remember to follow the instructions that come with the breaker. Always follow the sequence the manufacturer suggests. AFCI breakers require one additional step. You need to locate the white wire that is paired with the black wire in that circuit. The white wire actually attaches to the breaker as well. There is a coiled white wire that leads out of the breaker. This white wire attaches to the neutral bus bar in spot that is vacated when you disconnect the white wire of the circuit. If this answer scared you, call an electrician!
Posted on Aug 27, 2008
  • 653 Answers
SOURCE: 125 MAIN CIRCUIT BREAKER REPLACEMENT
I would tend to agree with "Tripleauto". If you do not disconnect the electrical supply to the house, you run the risk of having 240 volts at up to about 75 KVA coursing through your body. Needless to say, before the transformer blows out or someone cuts off the power, your corpse will be mostly ash. Call the power company to co-ordinate having the power turned off while you or your electrician do the work. Once the power is off, swapping out the main breaker is a relatively simple job, assuming you can find an exact replacement. If there is no exact replacement, as in the panel is fairly old and the breaker is no longer available, you will end up having to replace the whole panel or add a 125 amp breaker in a separate enclosure in an accessible location between the meter socket and the breaker box, preferably within reach of the breaker panel. The International Residential Code requires a disconnct where there are more than six breakers needed to turn off all power to the dwelling. Check with your local Building Code office before doing anything.
--Peter Nomikos, International Code Council Master Code Professional
Building and Zoning Director, City of Mauldin, SC
Posted on Feb 26, 2009
  • 653 Answers
SOURCE: Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Posted on Feb 27, 2009
  • 143 Answers
SOURCE: arc circuit breaker won't reset
yes
Posted on Sep 20, 2009
Testimonial: "thank you for the advice it worked and everything is working. "
  • 145 Answers
SOURCE: Can't find any ite bl circuit breakers.
YOU CAN CALL ITE FOR A DEALER NEAR YOU
Posted on Jan 08, 2010
Plugged new heater in, blew out right away.
The heater is pulling more amps than the circuit breaker is rated for. Have an electrician add a higher rated circuit breaker. 20 amp
Jan 13, 2015 | Cars & Trucks
Camper wiring diagram
Is there a switch or a GFCI in the circuit between the breaker and the unit?
Jul 28, 2014 | Water Heaters
Blown fuses
a popped breaker is a short in circuit, first check cord for damage, second it could be heater shorted to block. best checked with multymeter on ohms scale, circuit through block heater is usually 25 to 45 ohms.
Mar 13, 2014 | Duraflame DFS-550-0 Black Metal Electric...
RHEEM PRONTO MODEL #RTG-74PVN STOP WORKING YESTERDAY, BLUE CIRCUIT BREAKER. RESET CIRCUIT, PROVIDED HOT WATER FOR 2 MINUTES. THE TANK IS LEAKING WATER OUT THE RIGHT BOTTOM CORNER.
if it is leaking, and not just from any of the relief valves, you will need to replace it. There is not much you can do. If it blew the circuit breaker, there is probably a build-up of sediment inside that is surrounding the element and making it overheat. By the sounds of it, replacement is the option.
Sep 17, 2011 | Rheem Water Heaters
I have a briggs and stratton 8500/5500 generator which I am using to power an air conditioner on a camper trailer. I just recently started having a problem where the one circuit breaker keeps tripping when...
Hello, First figure out what the load per leg is on your generator. Are you using the 240 Volts because this is two 120 AC volts legs and they are 120 degrees out of phase with each other.
You will need to figure what the power factor is for each phase on this generator. To figure the power/wattage by using ohm's law. Voltage times Current will give you Watts. Example: If the generator is generator 240 volts the maximum current available is about 23 amps. The maximum current for 120 volts will 46 amps. Therefore, the maximum current per 120 volt circuit is 23 amps for one circuit and 23 amps for the second 120 circuit..
I would try replacing the circuit breaker with the same amperage breaker. Also, watch what the generator load is per circuit. You can install current meter for each circuit. This will give a good indication of which circuit is pulling more load than the other circuit. GB...stewbison
Sep 06, 2011 | Briggs & Stratton Power Products 5,550...
When plugged in, no power, dead and not functioning
Have you checked the receptacle that the heater is plugged in to, to see if it's still working? You can do this by unplugging the heater and plugging a lamp into the receptacle and turning on the lamp. If that fails, then there's a circuit breaker tripped in your home's circuit breaker panel. Check that and if you find one, make sure nothing is plugged into the offending receptacle and reset the circuit breaker.
Now, plug the heater back in. Does it work or does it trip the circuit breaker? If it trips the circuit breaker the heater has an electrical problem, that may or may not be able to be repaired.
Since you didn't mention what brand and model heater you have, there's not much more I can do to help you trouble shoot the problem.
Never the less, I hope this helps steer you in the right direction.
Feb 15, 2011 | Heating & Cooling
Computer/Motherboard Issues
buy a circuit protector for just ur computer and call a electrition
May 12, 2010 | Gateway 507GR PC Desktop
Fir sauna used for 1 hour, appeared to overheat and blew circuit breaker - now blows circuit breaker every time its plugged in. checked wiring and all seems fine. any suggestions guy
Does the circuit breaker match the load? And the wires match the load? Is this on a GFT protected breaker?
You say all the wires check out, how about the heater, did you take it apart or at least the cover to see if there is a short?
Please let me know what you find.
Thanks for using FixYa.com
a
Oct 28, 2009 | RTO 1 Person Ceramic Heater Far Infrared...
I have a 1994 Carri-Lite 633RKS camper with electrical problems
The clicking your hearing from the AC is probably just the 12 volt side of the circuit to run the AC, but it does indicate that the controls/thermostat is doing it's job, but doesn't sound like hydro is getting to AC as well as microwave. I can't imagine those being on the same circuit as far as breaker panel goes, but who knows what might have been done before you got it, unless bought new. Do you by any chance own a plug in circuit/receptacle tester, or anything like that to test for power? In the meantime, make sure AC is in off mode, then go to breaker panel & push breakers for microwave & AC, all the way off hard, then try to reset it & tell me what happens.
Sep 04, 2009 | Coleman Heating & Cooling
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
