Question about Sony Televison & Video
I cannot control the volume on my str-de598. The display shows it changing up/down. Pressing mute shows mute on the display but the volume is not muted...
  • Carl Aug 01, 2013
    Thanks, Ernesto. But the problem seems to be with the receiver and not the control. Pressing mute or turning the knob on the receiver does not change the volume level even though the display reads "MUTE" or the numbers increase/decrease as you turn the volume knob.
    Top Expert:
  • Sony Master
  • 12,223 Answers
Open the remote c. and clean the keypads form dirty, corrosion, oxide, use contacts cleaner and fix it.
God bless you
Posted on Aug 01, 2013
  • 38 Answers
SOURCE: Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Posted on Nov 28, 2007
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
  • 59 Answers
SOURCE: Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Posted on Jun 08, 2009
SOURCE: my sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Posted on Aug 05, 2009
SOURCE: Ive got a urc-3920 One for all remote . All
i have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
Posted on Apr 20, 2011
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
I can't get sound out of my amplifier and I haven't changed anything. What could be the problem?
Start by choosing FM on a known frequency with a station broadcasting and volume is turned down to a NORMAL listening level. Next, make sure speaker selector isn't the wrong position (make sure "SPEAKERS OFF/A/B/A+B is set to A [or B to match the speaker terminal connections]), check to be sure "Mute" function is not activated by pressing the MUTE button on the remote to toggle it between on & off, Make sure headphones are disconnected. Make sure "PROTECT" is not displayed on the front as this indicates a shorted speaker wire - shut off and repair the shorted wire(s).
If you get sound on FM, but have an issue with another external component (CD, DVD, Phono, etc.) check the cables between the component and the input panel on the rear of the STR-DE595.
I hope this helps & good luck!
Sep 13, 2011 | Sony STR-DE595 5-Channel Amplifier
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
Center channel volume decreases in surround mode, making it difficult to hear conversation in movies. How to i increase center channel volume?
There should be a setup button or menu button...when in setup go to surround settings and change to desired volume
Dec 27, 2010 | Sony STR-DE598 Receiver
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
It shows a crystal eye on the computer but still wont open the webcam.whats going on
Please follow the steps mentioend below:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following:
Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply.
In the Audio Volume section, use the slider bar to increase the volume level.
Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume.
Increase the notebook volume level by pressing the Fn+PgUp keys.
Mar 27, 2010 | Acer Aspire 3690-2196 Notebook
When I hook up the RCA cables from the Phono to minimal volume
PHONO requires a phono-equipped receiver, which the STR-DE598 appears to NOT be. AUX will not work because it requires Line Level inout. Traditional old-school turntables put out a very tiny drastically-altered signal which needs preamplification to raise it and flatten it out for use by downstream circuitry. THAT is the job of the PHONO section in a preamp or receiver. You need to find a phono preamp or an older receiver to run the TT through. You could slave it to the STR through its AUX then.
Apr 30, 2009 | Sony STR-DE598 Receiver
Centre channel
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b4bde15140d8c039f4d0e380f8615237&q=Sony+STR-DE598
Jun 28, 2008 | Sony STR-DE598 Receiver
STR-DE598
Well usually the best thing to do is unplug the unit from any power and leave it for about 2 hours to reset. that is a common problem when the unit has been played at a high volume or the speaker connection are not tight
Jan 04, 2008 | Sony STR-DE598 Receiver
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
